Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
How can I remove the ice drawer of my GE Profile side by side integrated ice machine?
There is a large clump of ice and it appears connected to a mechanism in the back. Is there something I need to disconnect in order to remove the ice drawer?
Posted by Meghan Garvey on
  • Meghan Garvey May 10, 2012
    I actually wasn't sure if the ice was blocking the drawer from opening and attached to the mechanism inside or if there was something connected to the drawer at the back. All I knew was that the drawer was stuck.. Re-reading my question and your post helped me realize that the issue was the ice had built up inside and was preventing the drawer from opening easily. After carefully shaking the drawer, the ice broke up and I could finally free the drawer. BEWARE.. do not use the "quick ice" function on this fridge if you have not read the manual. I did this and that's how I wound up with the ice clump problem!
RSole
    Master:
  • 697 Answers
Is it the clump of ice that's connected to a mechanism? That's what you wrote. Melt the clump until the mechanism is free at last, free at last, thank god almighty, free at last. (MLK)
Posted on May 06, 2012
5 Related Answers
dididsaythat
Mike Johnson
  • 291 Answers
SOURCE: ice maker not working
have you felt water in the ice maker or ice cubes thats the only way you know for sure.. just cause water in doors works doesnt mean icemaker getting water.. got different valves giving water to different places Is your freezer temp. right.. has to be right temp for icemaker to work.. check back wall in freezer make sure no frost buildup and if fan working
Posted on Sep 02, 2007
Anonymous
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
Anonymous
  • 531 Answers
SOURCE: GE Profile Side-by-Side - Ice Maker Issue - Water Overflowing
your icemaker is bad
Posted on Apr 02, 2009
Anonymous
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
DeBruce
Bruce
  • 145 Answers
SOURCE: Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Posted on Mar 05, 2010
My E profile has mold in drawers. I can't reach. How do I disassemble drawer to clean
The drawers will pull out the front, then you can unclip the drawer fronts, they are just held together by plastic tabs. GE Refrigerator Drawer WR32X10338
Jul 10, 2016 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice cubes are turning into a clump of ice
I found a high density foam and a plastic retainer under the freezer drawer, inspected ice maker and found a wire with a rectangular senser hanging down. Removed freezer drawer and door to gain access to icemaker. Reinstalled foam piece and plastic retainer to lower front of icemaker (there are recess and a small retainiing tab) Reassembled freezer door and drawer, system working normally
Feb 23, 2010 | Whirlpool Refrigerators
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Mar 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile side/side refrigerator which was delivered on 4/19/08. When the ice comes down the chute it makes a lot of noise - so much noise that you cannot hear another person speak within the...
Hello azcowgirl19
Welcome to fixya,
You said, You have a GE Profile side/side refrigerator which was delivered on 4/19/08. When the ice comes down the chute it makes a lot of noise - so much noise that you cannot hear another person speak within the same room. Is there anyway that this clattering can be cushioned?
Also, the ice seems to clump up into a large ball and when it tries to go threw the coils, it shakes and rattles the entire appliance. Other than removing the lg clump of ice is there anyway to prevent this?
Yes I do recognize the problem.
The ice maker has a couple of defective parts in it!
Lucky for you you still have a warranty for this GE Profile fridge and did not waste anytime looking into it!
In the USA, Call GE at 1(800) GE CARES , and tell them the ice maker has multiple problems so they can service it while you still have your full parts and labor warranty!
Let me know how it goes!
Please remember to leave a rating at our site before you leave!
Thank You, Huuum
Sep 30, 2008 | GE Refrigerators
Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Aug 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile refrg. with ice maker
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Jul 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not working
Sep 02, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
196 people viewed this question
Top Refrigerators Experts
Mike McBirney
Level 1 Expert
gbob59
Ron Rak
Ron Rak
