SOURCE: How do I adjust the flame on my Frigidaire model FGS383BADK stove?
its going to be listed in the installation manual ,not use and care, youre going to need to convert oven for lp gas. i would call the manufacture with the modelk number and ask for hte coorect conversin kit, for such a thing
SOURCE: Oven and broiler will not come on.
go to www.repairclinic.com enter model number and look for the igniter it seems to me you need to change this part. Note it is very fragile.
SOURCE: Hotpoint oven model rgb745wea1ww oven doesn't
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
SOURCE: The oven and broiler are
Make sure the controls are set properly that the ovenselector switch is set correctly and that the temperature switch is set to thedesired temperature. Where applicable, make sure the oven timer is set tomanual. Make sure the oven door is slightly ajar as per your owner'smanual. You need to check these following things: 1. Check for circuit breaker and fuse - to know how to checkvisit http://www.partselect.com/range-stove-oven+glossary+repair.htm#CircuitBreaker. 2. Check the power 3. Check the oventhermostat - visit http://www.partselect.com/range-stove-oven+glossary+repair.htm#CircuitBreaker. 4. Check boiler element - visit http://www.partselect.com/range-stove-oven+broiling-element-testing+repair.htm. 5. Check selector switch - visit http://www.partselect.com/range-stove-oven+oven-selector-dial-testing+repair.htm. 6. Check oven cycling relay - visit http://www.partselect.com/range-stove-oven+oven-cycling-relay-testing+repair.htm. After completing these entire tests you need to replacefaulty component. Hope this will help you. Good Luck.
