My philips srp5107wm/17 only changes the volume on my tv no matter what device i have the remote set on i.e. aux , cable etc
The Philips remote is set to "push trough" the volume/mute to the TV for devices that typically don't have a volume function. Older versions of Philips remote used to allow you to select the device to push volume to, but for some reason this is no longer available (or at least I haven't found out how to). So here is the solution I used.
Teach (learning function) the remote to use whatever device you like for volume/mute.
1, Press the button for the device you would like to change
2. Hold down "learn" and the button you want to teach ex. "volume up" until the red light comes on
3. Place the original remote of the device you would like to change the volume on 5-10 cm away from your Philips remote and press "volume up" for this example
4. Repeat these steps for the "volume down" and "mute" buttons
5. Repeat these steps for other devices you would like to "push through" volume/mute to a device other than TV
Hope this helps others. I did find that some devices like SAT may not allow you to change the volume/mute, but otherwise this workaround does the trick.
SOURCE: I have a philips srp5107wm/17
Did you try and look into your manual to see if there is a different code that you can use to reprogram your remote. Sometimes that will help.
