During spin cycle, it sounds like an airplane taking off. Repair guy says bearings need to be replaced @ $800!! Any way to find parts and do it ourself?
Yes you can buy the bearings and lip seal online,but you need to dismantle the whole unit and split the tub to change the bearings,its a lot of work,if your mechanically inclined it shouldn't be a problem,then when dismantled drive out bearings from front and back and make sure new bearings are set in place properly with no gaps in either edge,replace lip seal and reassemble unit and test run
SOURCE: Loud Noise - Spin Cycle
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
SOURCE: Loud Noise during spin cycle
I have a maytag that sounds the same way but washes and spins fine despite all the noise???
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
SOURCE: Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
