I don't have any other details.The green light blinks and sometines a quick red blink ,Then none and the pictures come out very dark.
SOURCE: WHY IS MY CAMERA NOT STAYING ON ?
It sounds like the memory card slot has been damaged in some way. This probably means a new circuit. I would suggest you find a Kodak service centre in your area. Hopefully the camera is still under warranty.
SOURCE: Internal memory is full
u go to menu -hit down to where it says auto -it will bring up auto and internal memory...hit internal...then u can delete your internal memory the same way u do on your chip..
SOURCE: how to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
the support site for that camera is here http://www.kodak.com/global/en/service/products/ekn036326.jhtml?pq-path=6839/15367
The internal memory is only 16MB and only 11MB is available for storage - as the camera is a 12.4 MP camera I would not expect you to be able to store that many "5" images on that memory - you need to get an SD or SDHC card for the camera - max size support is 32GB see page 4 of the advanced manual
Direct links to PDF verisons of the manual
Testimonial: "Thanks , You are the guru , "
SOURCE: transfer pictures from camera to card
First, make sure there's a card installed and that the camera's image storage location is set to internal memory.
Press the Review button, then the Menu button. Use up/down to highlight Copy, then press OK. Use up/down to highlight an option, then press OK.
You set the image storage location in the Setup menu.
