Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
The pressure is at 5 and when I connect the vacum hose to the skimmer basket the pressure goes to 0 and then nothing
1. Something is stopping the seal at the basket
2. The hose going to the filter housing is partially clogged or not sealed
3. If you have a 2nd filter basket before filter housing, clogged/not sealed
4. Filter is clogged and needs to be cleaned, not just dirt, but degreased
5. Leaking pressure valve if one is used
I had a large filter and regular pressure was well above 5 psi, (8 to 10psi) with everything cleaned and running, once vacuum hose was connected it jumped to 14 to 18 psi.
Posted on May 05, 2012
SOURCE: Pool skimmer has poor suction and I've adjusted
change the gasket on the pump lid. If this doesnt work seal inlet to pump with silicone as a quick fix - or replumb with teflon tape and teflon sealant. If this does not work you could have debris stuck in your impeller. Also check drain plugs to make sure that they are tight (reseal with teflon tape if necessary.
Posted on Apr 04, 2009
SOURCE: lost my prime in my
please check your impellar it sounds like it is broken this is the part that really moves the water if motor is ok then it would most likely be this .
Thanks for useing fixya
Rate me
Posted on May 03, 2009
SOURCE: losing pressure 2-3 min vacuum hose is attached to skimmer
de filters clog very fast i suggest put vac in pool put hose over pool attach a wet vac to get water out of hose remove wet vac and vac saves de and water
Posted on Jul 11, 2009
SOURCE: My pump pressure is low i close valve to pool pump
You have a suction leak or a clogged impeller
Posted on Aug 30, 2009
May 26, 2014 | Hayward SAND FILTER, PRO SERIES
Jul 27, 2012 | Intex Wet Set Above Ground Pool Surface...
Oct 10, 2011 | Polaris 3900 Sport Pool Cleaner ()
Aug 31, 2011 | Intex Pool & Spa
Aug 01, 2011 | Pentair Whisperflo 1 HP Pool Pump WFE4...
Sep 12, 2010 | Polaris 280 In - Ground Pool Cleaner with...
1) Pump not primed
2) Leakage of air into suction system
3) Impeller clogged
4) Valve in suction or discharge line partly closed; Suction or discharge
line partly plugged or too small.
5) Plugged basket in skimmer or hair in lint strainer
6) Dirty filter.
Sep 09, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
5)Plugged basket in skimmer or hair in lint strainer.
6)Dirty filter.
Aug 05, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Jun 09, 2010 | Polaris 180 In Ground Pool Cleaner In...
1.Pump not primed
2.Leakage of air into suction system
3.Impeller clogged
4.Valve in suction or discharge line partly closed or suction or discharge line partly plugged or too small. 5.Plugged basket in skimmer or hair in lint strainer.
6.Dirty filter.
Jun 06, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
181 people viewed this question
