Question about Protron PLTV-26 26 in. HD-Ready LCD Television
We were just given a pl26 tv, by can not find where to plug the cable connector into the tv, help
Posted by thetalchick on
robingreer
    New Friend:
This information may help
32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 ...32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 800:1 6ms ... Front Panel Controls: IR sensor ; LED; Top Panel ... Model: PLTV-32; Product Requirements: HDTV receiver
Posted on May 05, 2012
I have a ferguson tv box and wondering how to fix it to my tv
Depending on the model of this BOX and your TV, you may need a set of cables with RCA connectors for it, a coax TV cable or possibly an HDMI cable. Look at the device and the TV to determine what connector types you will need. If you had given specific information on the TV and the box I might have been able to assist you further. Best of luck - you will figure this out. Try YouTube or simply go to the Ferguson site and look for the model you have, they may even have a PDF manual for you at some sites.
Nov 20, 2017 | TV Box Televison & Video
How could I connect a Daewoo 42sm TV?, I can't afford cable so I use a converter box(analog to digital w/rabbit antenna)on my other TV and I was given this Daewoo TV and would like to watch it;please
If your converter box only has RF outpit connectors "F" type screw on it looks like this my be more of a monitor then tv.I took a quick look at the manual and didn't see any RF inputs so it appears it doesn't have tuners built in Looks like you'll need a box that has RCA output connectors.or others that will match what the monitor has on it for input types
Mar 06, 2014 | Televison & Video
Setup proscan tv
Newer tvs have a lot of input connections ( holes) and can be very confusing. With out knowing what kind of plugs you have I will try to help as best I can. First ,if you have a coax cable hook it to the corresponding connector. The coax is a pencil sized cable that has a center wire and a threaded nut. It will screw onto the threaded connector on the back of the tv. If you have RCA cables these will be color coded yellow for video red and white for audio plug these into the corresponding connectors. There may be more than one set of these connectors and may be marked input1 or input2 etc.make sure to write down which input you plug these into.you may also have colorstream cables there are three green red and blue. Some of the newer tvs don't have inputs for these but if yours does plug them into the corresponding colors. Another cable you may have is a s-video cable this is a single cable that has a multi pin connector on each end. Again find the corresponding connector and plug this cable in. The newer cable is called a hdmi cable and is a cable with a rectangular end. This one cable takes the place of the multi-pin s- video cable or the RCA cables. It also replaces the colorstream cables. If you were able to connect all your cables up. Turn on the tv. You may get a blue screen that says no signal. Don't panic take the remote and find the input button. Pressing the input button changes the tv to the various sets of inputs on the back on the tv. Press the input button several times waiting in between each press of the button for several seconds untill you find the input you connected your cables to. If your connecting a vcr make sure you have a video playing so there will be a signal for the tv to find. I'm not sure what a PVR is, but make sure it is playing some thing when you scroll through the inputs on the tv with the remote. Hope this helps.
Jan 03, 2014 | Televison & Video
LG 32CS460 Lost freeview after cable unplugged
Check the cable connectors and the connectors on the wall and TV to make sure the cat didn't break any of them. (It seems odd that a cat would be able to pull a coax connector loose - maybe antenna cables in the UK aren't threaded as they are in the U. S. A.).
Oct 19, 2017 | LG 32cs460 32" Inch Widescreen 720p 60hz...
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
Just bought a stereo mini to rca cable. i have a macbook and a 32" dynex tv. I dont know where to insert the cables on the tv.
you need a mini to two rca plugs cable; once you have this: connect the red rca plug to the left TV stereo rca connector and, the white rca plug to the right TV stereo connector
and, the mini stereo plug to your speaker jack on the macbook You will now have sound.
then: connect the video to you macbook using another either s-video or, vga cable to the TV
Aug 03, 2010 | Televison & Video
No video from dazzle to pc
Hi and welcome to Fixyah,
I have something that can help you with, please checked if this is the same settings.
If you follow any of the videos, it won’t work!
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100.
Step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
Step 7: The tricky part no one ever mentions: On the XBox 360 video cable, there is a switch that switches from HDTV to TV. You must switch this to TV!
Let me know what happen.
Apr 09, 2010 | Pinnacle Dazzle DVD Recorder
How do i set up my plasma tv just to watch sky on the tv i was given a tv pioneer pdp-42mve1 and have got the power lead and a lead with a scart and 6 push in leads coluers are green blue blackyellow red...
Hello Paul,
all you need to do is plug the power in, put the scart lead into the back of your Pioneer tv, the other end of your scart into the bottom scart of your sky box named TV.
you will also need to connect the sky cable to the box to receive your signal. its a F type connector ie it screws on.
The other cable you have with the 6 push in coloured leads they are Component cable and the red and white ones are Audio cables. You will not need these cable unless your sky box is a HD box then i would suggest you get a HDMI cable instead of using component (less cables showing) dont be fooled into buying gold plated HDMI cables as they do not make any difference to the picture Quality as the back of the sky box is alley and so is the telly. So please dont waste your money on that type of cable.
Hope this Helps
Little Dish Fitter.
Sep 02, 2009 | Fujitsu Plasmavision PDS-4222 42 in....
No display on tv
"please email me for further help if this dosn't help before you mark not helpful [email protected]"
first try updating your drivers at www.ati.com, I have to ask you to double check the connector your using to goto the tv, if your using a S-video cable check the port on the card your connecting to, if there are more then 4 pin holes in the connector you need a pigtail to connect to your tv, many video cards use a cable that is sold seperatly to connect to a tv, connector look like a s-video connector and a s-video cable will plug into it, but instead of 4 pin holes it has 7, 9, or 12 connectors depending on the card, and the type of output the cable has. most are 9 pin with composit, s-video, and componite connectors on them.
May 09, 2008 | VisionTek 7K RADEON 7000, (64 MB) Graphic...
Tv connector cable plug slips out
you need to replace your wall cable outlet. This can be purchased at any Radio Shack or Home Depot store. You will find two mounting screws , remove them and you will have access to the junction box. If the cable system was installed in the proper manner you will find a double male connector attached to the face plate by a single securing nut. Remove this nut and replace the double male connector. simple job, hope this was a help to you.
good luck----------------tomtaso
Nov 21, 2007 | GE 25GT240 25" TV
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
274 people viewed this question
Top Protron Televison & Video Experts
Ekse
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
