If my sources are correct, (Haven't worked on one in my shop yet), the eMachines T5212 desktop computer uses an Intel D101GGC2 motherboard.
The Intel D101GGC motherboard is Very similar,
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htmMotherboard Manual - left-click on English Product Guide [PDF], in blue.
Give a few seconds for the first page to come up, (Took 6 seconds for me), and for the PDF file to fully download, before looking through it. (Took 24 seconds for me)
1) Did you make sure the 24 -pin ATX main power cable, is plugged in tight?
Lock on the side is snapped in place?
Page 42.
Closer look at a 24-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
2) Did you plug in the 4-pin ATX +12 Volt power cable?
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4Page 42
That's power for the Intel Pentium D model 805 processor.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5212Are the cables (Wires) from the Front Panel of the computer, plugged in correctly into the Front Panel header on the motherboard?
Page 37
Are you sure the DDR2 Sdram ram memory module/s (Stick/s) are plugged in tight?
The best method is to remove it, or them, and reinstall.
This way you are assured.
Most of the time a ram memory module, or more than one, will be bumped loose when installing a Power Supply.
