Question about AEG Lavamat W1450 Front Load Washer
After starting wash the machine is making series of beeping sounds before stopping and end light coming on.
I have an AEG lavamat W1050 which would stop mid cycle and the end light would blink 11 times. I cleaned out the pump housing (which was chock-full of gunk) as per instructions in the manual. Initially it still did not work. I tried the error code reset instructions people mentioned on this post. Still no success. But the next day it seemed to work and then stopped, then work a bit longer before stopping. After 3 cycles it then worked as good as new with no problems. My advice is that the machine seems to take a while to clear the error.
Posted on Jan 21, 2016
This is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
Posted on May 05, 2012
SOURCE: AEG Lavamat w1450 electronic.
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
