We have just moved into our new house and when we turn the ducted heating on, it doesnt blow out some of the vents, i dont think there are zones set to the remote but when i try and change the zone that doesnt work anyway, any other reasons why this could be happening? Can i just simply reset the system and it may start again? By the way, all vents are open in case someone thinks i may be that silly.
SOURCE: we have vulcan ducted heating. there is no heat
As a tip, often if you open the hatch at the bottom, instructions should be on the inside ?
You should be able to get a manual online, by using Google search, try to find the make mode number and Google for it.
That's the best advise I can give, when there is no manufacturers make and model data available.
SOURCE: I have a Vulcan Bonaire
hi,
The heating coil itself have some problem that's why the circuit breaker clicks off by sensing over current drop. Check the heating coil and replace it.
ok
SOURCE: I have just purchased a
We can ask you more information in order to understand which system you have or we have here the link with all the systems owners manuals for you to mutch which one is for you. Also at the same link Bonaire have a list with service support and spare parts branches
