SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
SOURCE: ice crusher not crushing
Almost everytime I encounter this its the actuator on the solenoid sticking. Check this out, Pull the ice bucket out and you will see a rod on the lower back. This is what flips up and down to engage the crushing mechanism. Where this rod connects in the freezer is where this solenoid is. Try this, Open the freezer and with the ice bucket out hit the ice button, both for crushed and cubed ice while watching the solenoid. You should see it engage and move up and down along with an unmistakable thud. Some times all thats needed is to loosen the 2 mounting screws and realign the plunger. The normal resting place for the plunger is in the down position. I've also seen the plastic break on the plunger.
Theres also the possibility ice is jambed up, I've seen the bucket put in improperly, the solenoid itself could be bad, Or the control board tho unlikely. 95% of the time its a stuck solenoid. Hope this helps!
SOURCE: ice maker only makes crushed ice
on the bottom of the bin there is a metal rod, this goes into the back wall where the solenoid is. find the square hole it goes into, pull down the white plastic piece with your index finger. you should here a clunk. now put the bin back and check to see if ok. if not you may need to replace the solenoid assy.
SOURCE: Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
