Question about JBL EON 15-G2 Powered DJ Speaker With EQ Speaker
How to remove and replace jbl eon 15g2 speaker?
Speaker damaged. what does eq speaker mean? i just want to remove damaged speaker and have it reconed or replace it. i removed the back of speaker and can't see how to remove speaker. took front bezel off and don't see screws to remove it, it looks like everything is permanently "installed" connected.
4 Related Answers
Anonymous
SOURCE: jbl eon
the eon woofer is designed to fit the small frame of the inside cabinet. The EV woofers look too deep to fit but you can try. I do think that the built in amps were set to work with only the JBL woofers so there might be a signal problem using the built in amp. The eon face seems to have their own screws to hold the grill so if they aren't holding you can drop some cement to help hold the srews in place. The front does not allow removal of the woofer so it seems whatever you do should not effect anything.
Posted on Nov 08, 2008
Vito Vacirca Jr.
  • 140 Answers
SOURCE: I get a loud intermitant
If you turn the unit on with no input and get a loud buzz, and when you put signal to it and you cannot hear the music but the buzz (Probably more like a hum). Then most likely the amp is blown.
Posted on Dec 14, 2010
mega_mind
  • 162 Answers
SOURCE: i need a replacement volume control for jbl eon
Here is the link
http://www.fullcompass.com/product/368101.html
Posted on Mar 02, 2011
Anonymous
  • 591 Answers
SOURCE: My JBL eon 15g2 speaker was working fine and then
the braided wires from the speaker connectors to the voice coil could be broken (from repetitive movement) or it could be the voice coil it self that could be cut open from a miss alignment of the cone (ware and tear), delicately push on the cone and feel if it rubs, a simple test is to check the IMPEDANCE of the speaker with a OHMMETER, if you have a reading (4,6,or 8 ohms) than the speaker is fine, check the rest of the wiring, if it reads OPEN than you need a new speaker...
Posted on Apr 09, 2011
My jbl eon 15 g2 smell like burnt and everything works but the big speaker
The voice coil in the big speaker could have been damaged if driven to loud. See if the burnt smell is strongest near the center of the big speaker. If the voice coil is fried, you may be able to still find a replacement as there is a part number for the voice coil (V/C Assy, EON-G2220-27005-00) and the cone (EONG2
Cone Repl. C2REON15P-2)
3helpful
2answers
My JBL eon 15g2 speaker was working fine and then suddenly the lower woofer suddenly stopped. The higher tweeter still seems to work. All of the fuses are fine and all the wires seem to be properly...
I need a replacement volume control for jbl eon 15g2
Here is the link
How do you remove the HF driver in the JBL EON 15 G2's??? Cheers Glen
If the cabinet is all taken apart, unplug the white and blue wires and unscrew the driver counter-clockwise to take it out
How to replace damaged subwoofer? Opened cabinet and found that the woofers' voice coil has burnt and the cone can't move. How to replace it the damaged speaker?
Since the coil is attached to to cone, you are looking at replacing the whole 15" driver (speaker)
To get access to the screws that hold it in place, you'll need to remove the front bezel from the cabinet, then remove the screws around the speaker's rim.
For what it's worth, that driver isn't a subwoofer, it's just a 15" driver. JBL does make 15" and 18" subwoofer drivers, but they aren't the same speaker as what's in this EON. Hopefully that will help you when you're shopping for a replacement driver.
My JBL Eon15 g2 has a cracklin sound within the main component when the bass is turned up. How can I fix this?
it can be the amp or the speaker itself. it has to be diagnosed by a service center.
if the amp is the problem, there can be board replacements or component level repair. if it is the 15" speaker, then it can be reconed with authentic genuine JBL parts returning it to brand new. [email protected]
Jbl eon
JBL EON 15-G2 Powered DJ Speaker With EQ Speaker Logo
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
