SOURCE: Playstation3 and Denon AVR-1804
If you don't have a user guide, go to:
usa.denon.com From there, you can click on Support and search for archived info...you will find a pdf there.
Of your five plugs, a red and white next to each other will plug in to the audio in on your denon (Red is for Right) I would use something like the VCR-3 pair on the left side of the rear panel. The other three, Red Green and Blue are for Video Component In on the denon; Use either Video-1 or Video-2 in the component section on the right half of the rear panel.
At his point, it will be best to look at the manual, because you will have to pair the two items together in the menu system. It takes a little patience but isn't too hard.
Good luck.
SOURCE: Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
SOURCE: Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
