Question about Fisher and Paykel Washing Machines
Where is the curcuit breaker on f and p mw511
Posted by nsbarclay on
keith jones
    Master:
  • Fisher and P... Master
  • 747 Answers
Do you mean fuse ? if so its on the main computer board
Posted on Apr 21, 2018
1 Related Answer
Anonymous
  • 706 Answers
SOURCE: curcuit breaker pops
hello elanalex,
When your heater shuts off it trips your main breaker and that is usually associated with the interupt capacity of the breaker ( which means that while your heater is drawing current, if the thermostat says stop.. you are interupting that current demand abruptly and your getting a surge back to your breaker, You may be able to add a surge arrestor to that power feed to suppress that problem. You may also be able to repsecify your main breaker with one that has a higher interupt capacity.. Check with a local electrical supply house..explain the problem and they should be able to provide a hardware solution. Make sure you provide details on your circuit breaker brand so they can provide the proper solution.. GoodLuck
Regards,
Rick
Posted on Dec 04, 2008
Curcuit Breaker appears to be on but no power?
It sounds like something in that circuit is causing the overload. Disconnect anything that is in that circuit, flip the breaker, and one item at a time plug whatever was on that circuit back in until it trips again. Then try that item in a different circuit and see if it does the same thing. It could also be that the breaker is worn out and is tripping at a lower point that it supposed to. In that case you would have to replace the breaker.
1helpful
Where is the window curcuit breaker for a 2002 honda civic
Its probably the window motor circuit breaker should power all of them and only one doesnt work.
My child put dish soap in the washer and the suds have leaked through the door onto the floor. How do I clear up the suds from inside the dishwasher? This also caused the circuit breaker to trip and I...
Turn off curcuit breaker. Mop up suds and water with towel. Remove kick panel mop up water here and dry out with a fan. Replace Kick Panel. Reset Curcuit breaker. Add one cup of Vingar to bottom of tub. Run a rinse and hold cycle. Repeat if necessary.
Two 15 amp arc fault breakers installed on two adjacent circuits. One works fine - does not trip. The afi breaker beside it trips as soon as it is flipped on. We tried switching circuits, but both circuits...
It's possible that the first breaker that you said does not trip - it could be that breaker is failing to trip on a bad circuit. That is, it could be you have a bad circuit but that first breaker is not detecting it and pretends everything is OK. If your new breaker trips on the first breaker's circuit, the curcuit it probably bad and the breaker in not working properly. The most common problem for failed circuits is a stray ground wire in a box somewhere in the curcuit resting against a hot or neutral wire. You'll have to take apart every connection on that curcuit to find it. Not fun.
Timer wont advance will not heat
you either have a tripped curcuit breaker or your heating element is blown. If the timer cannot sense that the heater is in the curcuit it will not advance check your curcuit breaker first. flip it on and then off and let me know if you have heat
Curcuit breaker pops
hello elanalex,
Regards,
Rick
1helpful
Curcuit wiring
Black will normaly go to the breaker on a 110 circuit white is ground and the bare is secoundary ground..You should see this with the cover removed. BE VERY CAREFULL AS THERE IS POWER INSIDE THE BOX AT ALL TIMES AND A WRONG MOVE COULD SEND YOU TO THE UNDERTAKER,EVEN IF YOU TURN OFF THE MAIN BREAKER THERE IS STILL POWER COMING INTO THE BOX THAT COULD KILL YOU...If i were you i might call a friend ta help.
AIR CONDTIONER TRIPS CURCUITS
Possible loose connections on the wires to the breakers,
or in the unit. loose connections casuse the wire to overamp and trip the breaker.
Also it's possible the breaker it's self is bad.
there ar also other possibilites but the 2 formentioned is the most common cause.
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Ekse
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
