WHAT IS THE MODEL NUMBER
SOURCE: Wheel shaft seals on troy bilt pony 7 hp.
If the seal fits over the axle shaft it should be ok. be sure your axles are very clean as not to ruin the new seals when applying them. probably a good idea to replace them as a pair (right and left side) to save you time down the road.
SOURCE: troy bilt pressure washer
Turn Black cone shaped valve clockwise to increase pressure there will be a small +/- plus will increase and give you pressure.
TK U
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
