Can you help me
You may download a copy of the manual here.
SOURCE: I have lost my Nikon Coolpix 4300 users manual.
Download manual here:
http://safemanuals.com/user-guide-instructions-owner-manual/NIKON/COOLPIX%204300-_E
Please take the time to rate my response thanks.
Best wishes,
Mike.
SOURCE: Nikon Coolpix L18 Driver
You don't need the disk to transfer your pictures from your camera to your computer. Just take your sd card out of your camera and plug it into your computer. A folder with your pictures will appear on your computer. Copy them to a different folder on your computer, so you can take your sd card out and still have them on there.
If that doesn't work, plug the cable in that came with your camera, and hopefully that will work.
I hope this helps. Please rate my solution.
Try this, it may work without the software. Turn off the camera. Plug the usb cable between the camera and the computer. Turn on the camera. If a box pops up on the computer asking what you want to do, scroll down and see if there is an option to view pictures. If a window opens up with all your pictures on it, great. Now open up a folder where you want to put your pictures. Bring up the other window with the pictures in it and hit the control key and the d key at the same time on your keyboard. Then drag your pictures to the window where you want them and let go of the mouse key. They should all move over. Then you can use Windows image viewer to see them. Let me know if that works.
SOURCE: i have a nikon coolpix L 16
Hi Carlos, welcome to FixYa.
Yes you can use an SDHC card or an SD card. Either one is fine, but I would not go over a 4gb card because it might not work with your camera. (Nikon has only tested that camera with up to 4gb so they won't guarantee any more than that will work. You just have to try it and see.)
You can find the manual here.
http://www.nikonusa.com/pdf/manuals/noprint/L18_L16_ennoprint.pdf
Thanks for coming to FixYa.
Rob
SOURCE: my nikon camera coolpix 1600 memory card is write protected. Plea
Write Protection: There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
