Question about GE Marquette Eagle 4000 Vital Signs Patient Monitor with Ecg Nibp SPO2
My eagle 4000 is 120volts then it is accedentally plug in to 220volts. it blown the fuse at the power supply pcb board then i replace the fuse 10amperes but it still blowing.what could be the problem?
  • Anonymous May 17, 2012
    tnx sir Ajin for your info..God bless..
Electro Med Services
  • GE Master
  • 6,694 Answers
There will be an MOV (metal oxide varistor) After fuse. This MOV is rated 125v. When you plug the machine in to 220v supply this MOV will become shorted and its blows the fuse to prevent further dameges to the power supply. Replace the MOV and then insert the fuse. I have added the image of MOV here. It is placed parallel to the AC mains supply rail after fuse.
Ajin
Posted on May 07, 2012
I HAVE A JENNAIR JS42CSDBDA FRIDGE THAT WENT DEAD NO POWER,NO LIGHTS CHECKED OUTLET AND FOUND POWER GOING TO FRIDGE BUT NOTHING. IT ACTS AS IF IT'S NOT EVEN PLUGGED IN.
No one turned off your power switch up above the refrigerator, I trust. So, either your power supply or your main PCB is blown. Check the fuse on the main PCB (up on top of your refrigerator in the compressor area). The fuse will be right next to that round, black piezo electric speaker on the main PCB board as shown here:
If that's not it, then check to see if your power supply board is supplying power by measuring the voltage on JP11 of the Main PCB. You should see 26 vdc between pin 3 (GND) and pin 1. And, you should see 12 vdc between pin 3 (GND) and pin 2.
If you don't get those voltages, then you might have a bad Power Supply Board. It looks like this:
Also of note, your 120vac going into the Main PCB board comes in on JP8, pin 1 (WHT) and pin 5 (RED).
I don't know if you will be able to see the larger image of the schematic, or if Fixya will just give you a thumbnail, but I'll try to post it here, anyway:
Well, good luck and let me know if you need any more assistance.
Oct 20, 2014 | Jenn-Air Refrigerators
There is nothing on the display,conditioner is death.The power is coming,fuse on the PCB is OK?
Check power to transformer (220volts---24/12volts Dc) which leads to function PCB. If 24 or 12 dc is o.k, then you have replace PCB only.If no output of DC, replace transformer. Thanks.
Jan 29, 2011 | LG LS-K1830HL Heat Cool Mini Split Air...
My Dell Dimension 2350 won't power on. I've checked cables, power strip, reconnected cable to a known working outlet, and looked under the hood for a breaker. Any other suggestions?
There are four diagnostic lights on the back of the unit. This linke will provide you with what they mean. http://support.dell.com/support/edocs/SYSTEMS/dim2350/advanced.htm#1218079
If all four lights are off, your power supply has most likely died (or the internal fuse is blown). It depends on how far into the computer you are willing to dive. To check the fuse, you'll need to remove the power supply and then remove the cover from the power supply. The fuse will be on the main PCB board inside the power supply. If the fuse is blown, try replacing it (it may blow again). If it blows again after replacing, then the power supply will need replacement. If the fuse is not blown, the power supply is still the likely problem and will need replacement. Be advised that Dell power supplies are special made for Dell cases, so you'll need to be sure that the replacement you get is for your computer or you will have to do some case modifications to get it to fit.
Dec 21, 2010 | Dell Computers & Internet
My akai tv model lct3785ta will not turn on
Ok.. What is the status of the power LED at the front. Does it blink, change color a few seconds after its turned on? Do you notice any clicking noise from the set?
Please provide this info so that we can continue with the diagnosis.
Sai.
Jan 25, 2010 | Akai LCT3785TA 37 in. LCD HDTV
My wii console will not power on. have checked all plugs and everything is connected and outlet has power
HI. the power supply board has failed. There is a fuse(3amps) inside the power supply unit. you will need to remove the cover from the power supply to access this fuse. once inside the power supply, inspect the fuse. if it is truly blown, replace it. if the fuse is not blown, this will confirm a failed power supply unit. it should be replaced in this case...
Aug 04, 2009 | Nintendo Wii Console
No power at the power panel( Aqualink RS8)
if unit comes on write down all auxs then remove plugs replace fuse turn on then plug one in at a time till it blows then you know which auw then see if wires are burnt
Apr 25, 2009 | Jandy AQUALINK RS TELELINK KIT
P50hdtv10a y-sustain and pcb
I had this problem with a different brand plasma and it turned out to be cracked or missing solder on the power board lead to y sustain. I removed the power board, desoldered the connection, clean it up and then resoldered the connection. Everything works great now.
Jan 23, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Convergance Amp Problem
you need a new converence amp pcb. If you need to know where to get a replacement PCB let me know and I will post a link.
Aug 21, 2008 | Samsung HCN4226W 42" Rear Projection...
Canon Super G3 Copy Fax Scan
I gave up on it. I was able to disassemble it and get to the power supply PCB but the main fuse was not blown. A new power supply PCB was too expensive and I don't have time to troubleshoot the power supply. Thanks
dewberr
Apr 09, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
GE Marquette Eagle 4000 Vital Signs Patient Monitor with Ecg Nibp SPO2 Logo
217 people viewed this question
Top GE Medical Experts
Marvin
Marvin
Harrie
Are you a GE Medical Expert? Answer questions, earn points and help others
