The usb 's on the laptop dond work i installed a pcmcia cardbus i had to remove it now when i went to put it back in it will not lock back in
SOURCE: Acer & Win2k new Device PCMCIA MTD-0002
Try using this Unknown Devices program to identify the hardware. Then search the internet for the correct driver.
If this does not solve the problem then check with the computer manufacturer for a BIOS upgrade that could repair the problem.
The manufacturer's web site may also have documentation that identifies this unique problem.
SOURCE: Acer Travelmate 3200 usb dont work
sir my name is ayaz ahmed im system administrator in quetta textile mills limited in karachi pakistan please solved my problem thanks best regard ayaz ahmed
SOURCE: pcmcia slot not recognizing pcmcia card
If thats the case that the pcmci is working on other laptop but is not working on your laptop thats there is a fault within your Pcmci slot is faulty and what you will have to do is that if there is still one more place for you to slot the Pcmci then do that but if there is not then you will have to find a pcmci that will be USB then you can be using that for the main time before you desold the pcmci slot away from the laptop and resold a new one for proper functioning ok .thanks
Rate this solution .
SOURCE: 10 out of date installed drivers
http://support.acer-euro.com/drivers/downloads.html
THERE ARE ALL YOUR DRIVER'S
I hope this helps.
If this Answer goes some way towards helping to resolve
your Query, Problem or Fault, please take the time to Rate it. Doing so helps
Solution Providers, like me, better understand the needs and the point of view
of Askers, like you, and guides us in exploring the best ways to provide the
most comprehensive, useful and high quality Responses and Solutions we can. If
you need further help, please do not hesitate to post another Question or add a
Comment to this Question.
Thanks
for using FixYa
