Exercise & Fitness Logo
Anonymous Posted on May 04, 2012
Life fitness 9500 wax lift bord
Wax lift
4 Related Answers
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on Apr 12, 2010
SOURCE: I have a life fitness treadmill and put new wax in
you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
Anonymous
  • 208 Answers
  • Posted on Jul 07, 2010
SOURCE: life fitness 9500 is shocking users? help?
Hi, there is a service bulletin for this problem.
1) perform a continuity test on the power cord between the earth pin at the plug and any exposed metalwork of the treadmill (say an exposed bolt). If you get a reading of less than 1ω - that is good. If higher than this, try another part of the treadmill or trace the cause.
2) Ensure the Power outlet has a good ground - Your electrician could verify this for you.
The most common problems are static buildup on the Striding belt caused by users wearing polyester and scuffing their feet as they are running. This causes static buildup which gets discharged through the user when they come into contact with the treadmill frame.
Happy hunting
Anonymous
  • 5 Answers
  • Posted on Aug 20, 2010
SOURCE: I can't reset a fault named "wax empty" and my
hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
Anonymous
  • 8197 Answers
  • Posted on Feb 15, 2011
SOURCE: How to adjust the tracking
Please read the link below.
http://www.ehow.com/how_5148912_adjust-belt-treadmill.html
1helpful
2answers
Display screen says waxer disconnected how do I fix
Remove the motor cover and look for the Wax lift board , it's right by the motor controller and check all wiring going to it.
2answers
Lifefitness treadmill belt sticks even though wax bag is fulll
alot of times you have to remove the wax spray nozel and clean as the wax hardens over it
Life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
1helpful
How do i refill the wax on my life fitness 9100 treadmill?
open cover on left at rear of treadmill, disconnect pipe, fill with wax kit and then reconnect pipe, 2 screws to remove wax cover.
Finding total mileage and useage hours on a Life Fitness 9500 Treadmill
unfortunately, is NOT possible, Not miles or kms in treadmills.
You have to buy the eagle eye.
God bless you
Describe your 9100 Next Generation Remanufactured Treadmill Problem display shows waxer disconected ???
Dear Sir:
I will help you inmediately.
1) Display does not illuminate
when machine is powered
on.
Insufficient power source.
Plug treadmill into a dedicated amp circuit.
2) Loose 10 pin connection at
display console or wax/lift
control board.
Check all electrical connections for proper
attachment.
3)Damaged main harness wire
connection.
4)Replace wire harness.
Faulty display console or Wax/
Lift Board.
Verify if 8VDC is present at P1 pin, 3-4 and
12VDC at P1 pin 9.
a)If yes, replace Display Console.
b) If no, replace Wax/Lift Board. See How To...
Replace Wax/Lift PCB.
Use VOM digital (Voltimeter)
Hoping that you can resolve, if you need some extra help, please reach me.
blessing.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
In life fitness next generation operation elevation is not working.!What is the problem?
It will be one of three things: #1 faulty Wax/Lift circuit board that controls the lift motor,#2 the motor itself, or #3 a faulty home switch, which is the white plastic switch in the base of the machine which senses the home position or zero degrees elevation.
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
