Question about Mamiya Photography
Mamiya 6 MF light shield stuck
My light shield is stuck and the knob won't turn. Now I can't remove the lens. Is there some hidden place to press to simulate the shield being shut which will allow the lens to come off?
Posted by geokelly on
5 Related Answers
Anonymous
  • 667 Answers
SOURCE: aperture diaphram on mamiya secor lens 80mm f/2.8
The lens has a lever marked A/M near the aperture ring. If the lever is in the 'A' position, the lens will stay wide open until you trip the control lever at the back of the lens next to the rear optics. In the 'M' setting, you can see the aperture move as you change the f-stop setting on the ring. Set the lens to anything but wide open and move the control lever with your finger. You should see that aperture move.
Posted on Jan 14, 2008
Anonymous
  • 178 Answers
SOURCE: camera stuck with lens out & wont turn on =/
This happens with many cameras, whatever you do, do not force the lens back. You will see this as a suggestion on some blogs. Doing it might further damage the camera lens and other parts.
Here is a repair place that is very reliable: http://www.teleplancamerarepair.com/Olympus_FE_FE-370
WHen sending it in make sure you cushion it so it doesn't get worse when shipping.
Posted on Jul 08, 2010
dcramer531
Dcramer531
  • 1654 Answers
SOURCE: My exterior door lock (Kwikset)
Get a big scredriver and put it in the square in the middle of the mechanism and turn it till it opens, or you will just have to pry it out with the scredriver.
Posted on Apr 05, 2011
Anonymous
  • 3006 Answers
SOURCE: The lens is stuck in
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Polaroid service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Posted on Jun 19, 2011
cadesertmax
Frank Schultz
  • 274 Answers
SOURCE: Our grill will not light. When the knob is pressed
It sounds like your grill may have a glo plug type of ignition system if there is a light inside the grill instead of a spark to light each burner. If your grill is hard wired to the house elelctrical, it may be that a breaker is tripped and the power is not getting to the glo plug and the grill us using a battery back up to try and light the grill. The batterys do not last long, and when they get weak, the plug will glow, but not hot enough to light the grill. The other possibility is that you have a short, or some other problem, that is preventing enough voltage to reach the glo plug, the plug will glow, but not hot enough to light the grill.
Posted on Jul 04, 2011
How does one dismantle a mamiya 120mm mf macro f4 lens
Do you have a lens collimator and other equipment necessary to ensure proper alignment when reassembling the lens? If not, then take the lens to a good camera shop and have a properly trained and equipped professional do the job.
Dec 19, 2013 | Mamiya Cameras
My camera shutter is stuck and all I see through the lens is black?
Need servicing from the service center. They disassemble the camera & unlock the shutter from internal side.
Aug 09, 2012 | Mamiya/sekor 500 Dtl 35mm Slr Film Camera...
Mamiya C3 film advance
Hi there,Here's a link to a PDF instruction manual of your camera body.
http://www.cameramanuals.org/mamiya_pdf/mamiya_c3.pdf
It is possible that the crank handle is missing, as it is a removable piece. Bring your camera to a camera shop and see if they have a box of old parts to replace it with. You can either use a regular round knob, or (if you're lucky) one with a crank on it.
Aug 01, 2012 | Mamiya Used C3 Professional Tlr Body...
My 645 1000s shutter buttons wont pop back up.this is my 1st mamiya
You might want to check and make sure the battery is still good. If you purchased the camera used and didn't change the battery then this might be the case.
But in the mean time this is what you need to do:
1st-make sure that the shutter speed dial is set to any shutter speed other than the red circle w/red ring. If your camera is set to that it will drain your battery when not in use since it is designed to be an automatic setting. I set mine to 1/125th to do this push in the circular dial on the side and at the same time turn the knob.
2nd- locate the 2 levers on the opposite side of the shutter speed dial. Once you found them then position the back lever all the way forward towards the setting for "MULTI" and position the lever towards the front straight up.
3rd- then wind the film crank till it won't wind anymore and depress the shutter, if it is wound and the shutter release is still stuck then skip to the fourth step, if something happened and you heard a click then still proceed to the next step because no the shutter release will be temporarily stuck.
4th-Once both of these levers are in this position there should be a red button just behind the shutter release button on the top right side of the camera.... drum roll please...."Push the red button" what you should hear is a rather loud click, this click is the mirror releasing allowing you to: 1 wind the film crank and take another picture and 2 this also now allows you to see through the lens again (assuming that you have a lens on the camera).
In Conclusion: without a battery that is fully functional in the camera this is how the camera will operate once you get a battery for your camera then reposition the levers on the side of the camera opposite of what I suggested (this will be the normal operating mode for the camera with a battery) then when you wind the film crank and depress the shutter everything will function normally.
Jul 12, 2011 | Mamiya Photography
I installed a Mamiya lens on my RB 67 Pro S. I cocked the shutter and fired it. Now I can't recock shutter and I can't get the lens off. The lens blades are closed.
Hi RMT, I sueest you only one thing. Please visit the service center. Beoause you already cocked the shutter & make it fired. So please follow the link its really very helpful for you.
LINK
Thanks & waiting for your feedback.
Feb 17, 2010 | Mamiya RB67 Pro SD Medium Format Camera
Manuel lens dos not turn any more
most likely some of the gears are offline or collapsed. when that happens it gets difficult to turn. you could send it to mamiya for an estimate or to mackcam.com
Dec 31, 2008 | Mamiya 35mm f/3.5 Lens 645
Mamiya 645 Super mirror locked in open position
My mirror somehow got stuck open too, I removed the power winder and grasped the pins in the middle of the silver wheel underneath used to wind the camera. Turn this clockwise until it stops and shutter is completely closed. Test fire camera after. If it doesn't work make sure you wound it all the way.
Nov 25, 2008 | Mamiya 210219 for 645 Pro/Pro TL/Super...
C330 twin lens M.F camera
Here is a link to the user manual: Mamiya C330
Mar 26, 2008 | Photography
Open Questions:
Photography Logo
Top Mamiya Photography Experts
Tony Parsons
Tony Parsons
Tom Chichester
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
