Question about Timex Ironman Watches
Triathlon RSS 210. Where can I buy a strap? - Ironman Timex Watches
sahani Arun
    New Friend:
  • 21 Answers
From showroom
Posted on Oct 21, 2015
5 Related Answers
Anonymous
SOURCE: I have a Timex Ironman Triathlon Speed + Distance...
The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
How to replace the battery in a Timex Ironman watch:
This is easier if you remove one of the rubbery wrist bands.
1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
2. Remove the four screws that hold the metal back cover, and pry off the cover.
3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
5. Replace the clip.
6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
8. Insert screws.
Dave
Posted on Jan 25, 2008
Barbara Phillips
  • 29 Answers
SOURCE: Setting time/date on Ironman Triathlon 8 lap
Press & hold set button the seconds will flash.
Press split/reset to set seconds to zero
Press mode to select hours
Press split reset to advance hour digits go through 12 hours to get to AM/PM
Press mode to select minutes
Press split reset to advance minutes
Keep repeatin the above steps to set month date day and 12/24 hour diplay
Press set when done.
Posted on Mar 11, 2008
Anonymous
SOURCE: Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Posted on Jan 19, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Timex IndiGlo Ironman Triathlon - bell stopped working
You have lost the coilspring wich connects the watch mechanics with the speaker integrated in watch caseback. This is why you do not hear any sound but still can see the icon.
Check the area where you made the battery replacement very carefully- you may find that tiny spring. Use the magnet if necessary.
If you can not find it, go to the nearest watchmakers shop and ask to supply the new coilspring.
Do not forget to rate, please.
Posted on Feb 03, 2009
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
Posted on Jun 08, 2009
Where to find timex replacement strap for T5K212F5
Per the watch's manual (page 41 in W246_M811_NA_EN.pdf) which is downloadable from the timex site
"Should you need a replacement strap or band, call 1-800-328-2677."
May 05, 2012 | Timex Sports Ironman Triathlon 100-Lap...
Watch strap that holds face of watch separates and face falls off
mcdevito75 here, Besides online with Timex for another original strap, you can also look for a small watch repair shop in your area for a replacement strap.
Jul 05, 2010 | Timex Ironman Triathlon 50 Lap Digital...
Trying to set my timex Rss 210 Heart Monitor Watch
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
May 27, 2010 | Timex Ironman 30 Lap 53952 Wrist Watch
Where can i purchase a replacement watch strap for aTimex ironman triathlon 877 n8
You can purchase it from :-
http://www.voguestrap.com/
A POSITIVE RATING IS HIGHLY APPRECIABLE.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 06, 2009 | Timex Sports Ironman Triathlon 50-Lap...
Ironman Triathlon Sleek Ladies Watch Band Rubber Strap Discolors
Unfortunately there is no way to get rid of that discolouring.This is due to sunrays+swetting+chemical composite of strap material. Would be too long to explain how it works, so, here is the link where you can order the new strap:
http://www.timex.com/gp/node/n/256542011/ref=sc_bb_c_11_251377011_15/190-2521384-6105829?ie=UTF8&node=256542011&no=251377011&timexBrand=core&me=A1S5XB33AHYRMX&clicked=center-1115
Rate me, please.
Jul 20, 2009 | Ironman Triathlon T59211
Ironman Triathlon Sleek Ladies watch Band problem.
try simple free or a citrus solution often found in household cleaners. js
May 24, 2008 | Watches
Watches Logo
1,088 people viewed this question
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Timex Watch Expert? Answer questions, earn points and help others
