Alpine IVA C801 Car Video Player Logo
A
Anonymous Posted on May 03, 2012
Where do i get a copy of IVA -C800 wiring diagram
5 Related Answers
Anonymous
  • 6966 Answers
  • Posted on Jan 10, 2008
SOURCE: help
Depending on the vehicles wiring itself, Alpine uses the below color coding for its wiring:
yellow – constant +12v such as the positive battery terminal
red – switched 12v such as the accessory terminal of the IGN switch
black – ground which could be the chassis/body ground of the vehicle or the negative terminal of the battery
blue/white - remote trigger for add-ons such as a power amplifier
blue – will activate a power antenna (if present)
white and white/black - front left speaker + & -
grey and grey/black - front right speaker + & -
green and green/black - rear left speaker + & -
purple and purple/black - rear right speaker + & -
orange/white - reverse wire
white/pink - monitor control lead
pink/black - audio interrupt from mobile/cell phones
yellow/blue - parking brake
yellow/black - foot brake
To bypass, the yellow/blue must be triggered negative/grounded. Alternately, it may be easier to use an adapter such as a Peripheral PTR7 (http://peripheralelectronics.com/). In some regions, it is not allowed to operate this unit while vehicle is in motion.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck, kind regards and drive safe.
Anonymous
  • 6966 Answers
SOURCE: Manual For Alpine IVA-C800
A copy of the manual for the Alpine IVA-CV800 is available for download from the company's website. Click on the link to download. It's a 251 pages pdf file,
Good luck and kind regards.
A
Anonymous
  • Posted on Feb 01, 2008
SOURCE: IVA C800 ALPINE
I BOUGHT ONE OFF EBAY AND TRIED TESTING IT OFF A 12V CONVERTER. COULD NOT GET IT TO TURN ON! INEED HELP TO
Anonymous
  • Posted on Mar 06, 2009
SOURCE: need brain unit and wiring harness
GO TO EBAY........... ADVANCE SEARCH TYPE IVA C800......
Anonymous
  • 15935 Answers
  • Posted on Apr 24, 2009
SOURCE: how do i get the navigation to work for the Alpine
CLICK HERE for your owners manual in PDF format.
The iva-c801 is NAV READY... meaning it needs the optional NAV unit... it is not built into the radio.
The NAV unit is an OPTIONAL piece from alpine. If you do not have a seperate brain for the NAV installed SEE THIS LINK - you do not have this feature.
If you have the NAV unit...(p27 of the manual states:)
If an optional Alpine Navigation System is
connected to the IVA-C801/CVA-1006, some of its
functions can be controlled from the IVA-C801/
CVA-1006.
The functions and display indicators available will
vary depending upon the Navigation System
connected. For details, consult your Alpine dealer.
1 Press the SOURCE button. The main menu
screen appears on the display.
2 Rotate the rotary encoder and select "NAVI,"
then press the rotary encoder to execute the
selection.
The Function Guide display changes to show the
same button names as those for the remote
control supplied with your navigation system.
NOTES
When the V. SEL button is pressed while the
Navigation selection mode is being selected in the
VISUAL setting (refer to page 43), the navigation
mode will be directly activated.
If the Navigation mode menu is not displayed on the
main menu screen, select "AUX IN" in the Setup mode
screen and set the Navigation mode to the ON
position.
If you use the buttons displayed, you can control the
navigation system from IVA-C801/CVA-1006 in the
similar way to the remote control operation.
For operation, refer to the Owner's Manual for your
navigation system.
Depending on the navigation system connected to this
unit, some functions and displays may vary.
Let me know if you require further help.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
2helpful
3helpful
Need wireing diagram for alpine 1VA-D310
Hello! Google: Installation Guide Alpine IVA-D310
Go to second page (choice # 11)...
Click on (pdf) IVA-D310 (first choice on page)...
Guru....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
2helpful
Where does the parking brake wire hook up in order to bi-pass this option on alpine iva-c800 car audio system
based on my previous experience with the Alpine Mobile Multimedia Station, 1 wire needs to see 12 volts ie. brake light wire, the other needs to see ground ie. parking brake.
You can hook up the wire that needs 12 volts to either ignition or some other 12 volt source. The other wire needs to be connected to a toggle switch to ground. Then flip the switch as needed to simulate the parking brake and voila...
Wirind diagram
Manualfox.com is a personal Document Search Service for electronic user and service manuals. They help you to save time and money by finding your needed product information.
2answers
Need brain unit and wiring harness
i need a brain unit 4 an alpine IVA-C800 please help!
IVA C800 ALPINE
Motorized Screen gets stuck sometimes - Any fix for it?
Mine does this too, it need a new gear for the actual flip out, if you send it to Alpine they will fix it for around 25 to 30$$.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
ZJ Limited
ZJ Limited
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
