Question about Panasonic KX-T7731 Corded Phone
Panasonic KX-T7731 Programming Manual - Panasonic KX-T7731 Corded Phone
Posted by John Powell on
Joanne Krig
    New Friend:
We have two phones KX-T7731 (Main phone) + KX-T7020 in another office. We talking on phone and another call comes in it use to ring on the spare phone. Now it does not ring until 4th ring and goes right into answering machine. It use to ring on second ring. Is there a way to program phone to ring on second phone after second ring?
Posted on Apr 28, 2015
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: How do I set the time and date?
You must be on the main phone on jack 01 to set time. You can determine if your phone is jack 01 by pressing PROGRAM and then pushing the number 6 on the dial pad. The phone will read the jack and extension number. When you have determined the jack 01 phone, do the following. 1. Push PROGRAM key 2. Dial "0" 3. Enter year (last 2 digits) 4. Enter month (01-12) 5. Enter day (01-31) 6. Enter day of week (Sun 0, Mon 1, Tue 2, Wed 3, Thu 4, Fri 5, Sat 6.) 7. Enter Hour (01-12) 8. Enter Minute (00-59) 9. Press 0 for AM 1 for PM 10. Press "AUTO DIAL/STORE" key 11. Push PROGRAM key to return to normal mode.
Posted on Sep 16, 2007
Anonymous
  • 4 Answers
SOURCE: Changing date on Panasonic KX-T7731
If it is displaying "101:" that is your extension. You can press the * key (with phone on the hook) to scroll your display through date and time formats and to display your extension.
When it says "PITS-PGM NO" you will need to press one of the buttons on the numerical key pad to choose a function to change.
Hope this helps!
Posted on Apr 09, 2008
checkitright
CheckitRight
  • 1363 Answers
SOURCE: KX-T7730 programming manual
http://www.retrevo.com/
Posted on Aug 07, 2008
Anonymous
  • 113 Answers
SOURCE: Panasonic kx-t7731 phone.... How do you set the
While the hanset is on the cradle press # or * until the desired display is shown. If that does not work press the info key below that is shown on the screen.
Posted on Mar 18, 2010
cnavarro
Carl Navarro
  • 2460 Answers
With the phone idle, you keep pressint the * (or the TRANSFER key) until what you want is on the display. It uses one or the other key because the 77xx phone works on more than one system.
Carl
Posted on May 11, 2010
Change auto attendant panasonic t7731
You may download a copy of the quick reference guide at http://www.ask-tsc.com/pdf/KX-T77xx.pdf
The KX-T7731 is just the phone. The auto attendant is controlled by the PBX. To change the message, please consult the manual for the PBX. If you don't have that manual, please reply to this post and specify the model of your PBX.
Mar 24, 2014 | Panasonic KX-T7630 Corded Phone
Hi how do i connect panasonic kx t7731 phone to kx tm 100b answering mcchine. i do not know what system i have and i connected as manual and it is not working. thanks
That's because whatever system it's connected to, it either has to be in the port by itself, or you have to BRIDGE the answering machine in system programming. You pick.
If it's a port on a TA series, you can tell the system there's an answering machine on it and it will let you override the incoming playback and pick a call from the line.
Carl
Aug 18, 2011 | Panasonic KX-T7731 Corded Phone
How do use my caller id on my kx-t7731 telephone?
Caller ID requires 3 things, service, hardware, and programming. The hardware is a CID card with a part number ending in 93, as in TA62493,82493,TD193 etc. Then system programming in the 900's turn it on for each CO line and the phone needs to be ringing to display CID when the phone rings.
Carl
Apr 21, 2011 | Panasonic KX-T7731 Corded Phone
Is the KX-T7731 caller ID equipped?
The CID comes from a card with a part number ending in 93 as in 62493, 82493, 84893, etc. That and programming will display CID to Panasonic system display phones.
Carl
Feb 22, 2011 | Panasonic KX-T7731 Corded Phone
Number of rings
In your voicemail system programming menu set the time period before which the voicemail clicks in. Usually 10 or 15 seconds.
Jul 09, 2008 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7731 Corded Phone Logo
1,933 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
