Question about Xerox Phaser 4500/B / Phaser 4500/YB Laser Printer
How do i find info on duplex printing on a canon pixma 4500
Posted by alan ferris on
Chris Hingee
  • Xerox Master
  • 32,281 Answers
This model Canon printer does not have a duplex unit and cannot print double sided printing automatically.
DOUBLY SIDED PRINTING WITHOUT A DUPLEX UNIT
Open your Word document.
Open page 1 - then Print the current page.
Then put the printed page 1 back in the paper tray upside down.Open page 2 and Print the current page (page 2 will be printedon the other side of the page 1).
Repeat this procedure for the other pages.
Posted on May 04, 2012
5 Related Answers
Anonymous
SOURCE: canon printer
clean the feeder rupper or replace them
Posted on Jan 15, 2008
Anonymous
  • 1605 Answers
SOURCE: canon Pixma 4500 when printing
the Magenta ink cartridge is leaking. replace with a new one.
clean the ink cradle before insert eh new one.
Posted on Nov 12, 2008
Anonymous
SOURCE: canon pixma 4500
HI
FIRST YOU HAVE TO MAKE SURE YOU HAVE PURCHASED THE CORRECT WHIT PRINTABLE DISKS.
YOUR PRINTER WOULD HAVE CAME WITH THE NECESSARY SFTWARE CALLED CD PRINT.
OPEN THE PROGRAM AND FOLLOW THE INSTRUCTIONS TO CREATE THE IMMAGE ON THE CD/DVD.
YOU WILL BE WORKING WITH AN IMAGE OF A BLANK WHITE DISK, AND WHAT EVER YOU DO THERE WILL BE PRINTED ON YOUR REAL DISK.
YOUR CANNON PRINTER WILL HAVE AN OPENING IN FRONT WHERE YOU WILL HAVE TO INSERT THE DISK WITH THE PROVIDED TRAY ( A BLACK RECTANGLE WHICH THE CD/DVD WILL FIT ON).
FOLLOW THE INSTRUCTIONS ON THE PC AND YOU CANNOT GO WRONG
Posted on Jan 14, 2009
Anonymous
SOURCE: Canon MP610 Printer When automatic duplex
I haven't found a way to do this using the printer settings.
There is no (apparent) simple solution, but needing tp print a 56 page pdf form the only solution was to load the pdf into Adobe Acrobat and then in the 'document' pull down menu select 'rotate pages', then select '180 degrees' and also 'rotate even pages only'. This then prints OK.
The down side is that you need full Adobe Acrobat rather than just the reader.
I have been unable to rotate pages through 180 degrees in MS Word but it is possible using MS Publisher.
Misterfish
Posted on Feb 11, 2009
JM Alvis
  • 164 Answers
SOURCE: how to memory delete
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Posted on Mar 31, 2010
Canon MX-310 printer: How to remove double-sided printing option?
Duplex printing is set in the print dialgue box. You may have set a profile where duplex printing is automatic and the computer is defaulting to that setting. Make sure it says "Standard" in the print dialogue box.
May 02, 2011 | Canon PIXMA MX310 All-In-One Printer
I have a Canon MX-310 Printer. Excellent. But, how can I print pages double-sided?
Hi!
Unfortunately it does not have a duplex function and you will have to manually duplex the pages meaning,Print and turn the page around and print on the other side!
Sorry!
Apr 02, 2011 | Canon PIXMA MX310 All-In-One Printer
How to set a MG5220 printer to do 2-sided copies?
The Canon MG5220 has a built-in auto duplexer and can print 2-sided documents. On a Mac, click print, and in the print dialog box select Duplex Printing & Margins (drop down options below Printer and Presets). Check the Duplex Priting box, and selected the Stapling side. Then click Print. That's it!!
Feb 05, 2011 | Canon PIXMA iP90v Printer
How do I use two-sided function on my PIXMA MP780?
To print "two-sided" (a.k.a. duplex), open your printer's properties before you print, go to tab "page setup" and check "duplex printing".
Hope this helps,
Stephan
Oct 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Can the canon pixma 860 print a sheet of paper in duplex mode
Hello !
Your printer prints 2-sided and you can change the orientation of output from portrait to landscape.
Hope this helps.
Oct 04, 2009 | Canon Office Equipment & Supplies
Unable to duplex
Make sure that duplex printing is enabled in the drivers when you print. It should work. You might have to manually tick that option and it might not be enabled by default.
Dec 14, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Duplex printing won't work
There is no duplex on this printer, two sided printing is only achieved via manual feeding, I checked the canon website spec for the MP460
Oct 09, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Xerox Phaser 4500/B / Phaser 4500/YB Laser Printer Logo
406 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
