Question about Freezers
Freezer wont switch off
Freezer stays on all time,when unplugged, then plugged back in,can hear thermostat switch off,but when comes back on stays on
Posted by peter ironmonger on
mike cooper
  • 884 Answers
Needs new thermostat. If trying to switch off and compressor still running, contacts stuck together. Many freezers run like this for years!
Posted on May 07, 2012
2 Related Answers
johnychel
isaac johny
  • 796 Answers
SOURCE: freezer lights but wont come on
thank you for rating.......
in the manual they do not include the various major do`s and dont`s
this is my sole expericence....its true , if the freezer is turned off for many days ....the oil inside compressor gets solidified
Posted on Feb 29, 2008
shastalaker7
Robert Horton
  • 1515 Answers
SOURCE: My upright freezer won't get cold. We unplugged
Hi, when you defrosted this upright, did you use hot water or a heat gun to do this? No sharp pointed objects at all? I'm sorry to ask that, but have to as I have seen this many times ending in a tiny hole in the evaporator coil and loosing all of the freon over night. Nothing but the small condenser fan would be on. With the lights on we know there is 120 volts to the unit. If the freezer fan is not on it's because it is temperature operated and comes on at a certain factory set temperature. Sounds like it may well be the thermostat control inside not calling for cooling. It will have an aluminum long probe on it that senses the box temperature. The control that raises and lowers the box setting. Check to see if it is working by turning it slowly colder and see if you hear a very light click at all? This is what brings this system on and shuts it off when satisfied. The unit may be stuck in the defrost position not letting it come on. It may also be the defrost thermostat that is located in behind the panel inside the unit, back panel along with the defrost heaters.This box should go into defrost on its own and you should not have to defrost it. For now, concentrate on the thermostat control. If you can't get it to start, unplug it and try pulling this stat out just enough to see if something has come loose as a wire. This does happen. There is not a lot that you can check on your own. I am trying to give you some ideas according to what you have said that happened. So, if you know there is no way you may have chipped away at the ice and put a small hole anywhere, we know you have freon in the system. If you can get to the wires on the stat, you can test it with a jumper wire if you have a piece of 12 to 14ga. insulated wire laying around. If so, pull it out enough to see the wire terminals. Be careful as you will be plugging it back in!! I don't want you to take a shock, so please be careful. I know you can do this safely. Now, just take one end...make sure both are stripped and hold it on a terminal by the insulated part. Take the other end and depending on how many terminals it has, touch it to all, but the green ground wire terminal, one at a time and see if it starts. You will see it spark but don't panic this is normal. If it starts and runs, that control is bad and will need to be replaced. You can get all the numbers, serial, model, name and all and get one at a appliance parts house. If the unit does not start, contact me by my user name and we will go deeper into it. I believe it will be this control. Best of luck,
Sincerely,
Shastalaker7
Posted on Mar 13, 2010
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
My freezer wont switch off
See previous answer
May 03, 2012 | Freezers
My power wen out and now my kenmore chest freezer high temp alarm is beeping and now it wont cool
I'd turn unit off...unplug it for a few minutes...plug it back in...and turn it back on setting the thermostat again.
Hopefully, you'll hear the compressor kick in and start cooling again.
Hope this helps...
Jul 23, 2011 | Freezers
Won't turn on
To determine which component has failed please do the following.
Unplug the freezer wait 5 minutes and plug back in. Listen closely for any sounds by the compressor. If you hear a click or hum followed by a click the problem is the compressor and would cost about $400.00 to repair.
If you do not hear any sounds the problem is most likely the cold control or sometimes called the thermostat. The part number is WR09X10053 and is about $25.00
Apr 25, 2010 | GE 5 cu. ft. / 142 liter Chest Freezer...
It quit running and everything thawed. It's got electric going to the dial. plugged it in and can't hear anything running.
The power coming into the fridge goes to the thermostat and when it's time for cooling the thermostat tells the compressor and other components to come on so it has to be the thermostat..Does the light insinde the fridge work? If so i would replace the thermostat and it should fix the problem!!!
Nov 06, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezer due to brown out then power restored now low temp alarm
The light should reset itself when the freezer gets to less then 18 degrees. If it is still above 18 degrees it will stay on. Now if it is cooler then 18 degrees then unplug the unit for 1 minute and plug it back in once you are sure that it is below 18 degrees. But do not rule out the thermostat. It could have blown out when the brownout happened. To test it jump the wires together and see if the freezer comes on and goes off
Feb 14, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezer freezes and then thaws
check wiring into outlet and at breaker that feeds outlet. you may be losing high volts at or to the switch. if possible check power into the stat when the condition occurs. this will telll you if stat is bad or power into it aka the outlet is bad. you may be jiggling wires in the outlet enough to fix short term each time you replug to outlet or get a good heavy extension cord and plug in else where to seee if problem goes away.Good luck
Dec 06, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Freezer not freezing
it would apear the stat is the fault. the thermostat is monitoring the temperature of the inner liner and tubing. if the compresor isnt actuly staying on the only part controling it is the stat. if you have the knoledge i would sugest you bypass the contol with the unit unpluged and the plug it in to conferm the fault was the control. p/s you may have a friend who has some knoledge . the control is a simple switch. just enshure the unit is unpluged. hope this helped
Oct 19, 2008 | Freezers
Freezer lights but wont come on
Feb 29, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Freezers Logo
55 people viewed this question
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
