Question about Alesis MasterLink ML-9600
Want except the os file
I try to down load the os file and put the cd in the alesisi it want recieve it it will still ask the the os file
Posted by bobby d hill on
googler too
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
I found that downloading and writing of the OS to a CD was operating-system dependant - I spent ages trying to get an OS downloaded through WIndows Vista to work, with no luck, but when I found a previous OS disc that I'd created with XP, that worked fine.
Posted on Oct 27, 2013
ROLAND 2480 RECIEVE ERROR MESSAGE SUB SYSTEM NOT RESPONSE
This means the low-level part of the operating system is corrupted or missing. Simply try reloading the OS by putting the CD into the CD drive. If it does not allow an OS reload or if it fails, most likely the flash ROM which holds the basic part of the OS has been zapped and will require service. You can also try to replace the internal button battery inside that retains the memory.
2helpful
My sceen is dark and i dont know what setting that change it
There are some files in the [ Windows 32 ] are missing or not function properly . You can fix the problem by repairing the OS .
Here is how to repair OS .
I had this problem before . What I did to solve it ? . I took the OS CD [ windows xp ] and inserted it in the CD driver .
I rebooted the system .
While the system is rebooting , I started booting from the CD .
When the computer asked me , if I want to install fresh copy of OS I agreed with it .
After that the computer will load some files from the CD .
Then It will stop to ask me again if I want to install fresh copy of OS or I want to repair the OS , I chose repairing OS ..
That's it . Just repair the OS and problem will be solved
I hope that will help .
please don't forget to rate if solution is helpful .
2answers
How to reformat hp laptop?
restart the pc. then boot from a cd e.g xp pro setup cd. then install the software and when it asks you to choose where you want to instal choose the local disk,c:, and choose to completely reformat this to a ntfs file system. note by reformatting you will be deleting all files in the computer and i suggest that you back the partition up to external devices.
Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
I was formating my philips PC and computer was accidently turned off before process was completed. Unable to load vista now as system recovery file is missing or corrupted.
Reformat it again. If it doesn't try the OS of service pack 3 black. Or format it again with your Vista, Check the boot priority on your Bios. Disable all listed except the DVD/CD rom/ram Then load your DVD/CD then follow the instruction.
2answers
How do I change boot order on Dell Diminsion 2400 XP Home?
Have you tried using a boot disk that gives you cdrom support?
If not, download those files and make a floppy boot disk, then set bios to boot from floppy and toss that disk in.
I think this website should have the files you need
Hope that helps you
2answers
Operating system installation error
Instead of adding the restore cd put the operating system cd & load the OS ..........but proir see that you have the backup of all of your documnet...........IF you have c/d/e drive then go directly to load the OS...........
Server2003 enterprize edition
Hey There,
You are getting this problem b'cause loss of ur system file i.e. "CONFIG.SYS", Which loads ur initial files and drivers needs to start ur operating System.
You must follow the steps given below to start repairing ur System:
1. Insert the Bootable OS Disk into ur CD/DVD-ROM.
2 Reboot ur System.
3. The system will prompt You to "Press any key to boot from CD".
4. Press Any key.
5. Now the system will load all initial files and hardware driver.
6. After loading driver and files, OS will ask you for acceptence with their Terms and Conditions.
7. You must Agree with terms and condition. press F8 key for accepting terms n conditions.
8. After step 7, OS will search for the partition of ur Previously installed OS. If you have two operating system then it will show two Partitions with their name and drive letters. (You must remember the drive letter where ur OS is installed that u want to repair)
9. Now Leave that option as it is. And press Escape key.
10. Now You'll be able to see all those partitions you have on ur Hard disk, with their drive letter, Name and free space.
11. Select the partition of OS that u wanted to Repair, By Scrolling Arrow Keys. (Be carefull while selecting the Partition. If you select wrong partition then You wont be able to repair ur OS)
12. And then Press "R" Key from ur Keyboard.
13. Now OS Will search for the partition you have specified.
14 It will Delete Old system files and Copy New files (Note: You won't loose any data, Previously you had saved on ur boot partition).
15. After Step 14, OS will save the configuration and Will Reboot itself.
16. Again You will be asked for "press any key to boot from CD". Don't Press Any key at this step.
17. Now follow the wizard n specify correct information you will be asked.
18. It will take about 20 to 30 minutes to Repair ur OS.
Note: These Steps are not valid if you are using Windows Vista
Romy_Dec
Fail to load files during text mode setup
Maybe its a software problem, have you tried putting in a bootable XP installation CD? After the bios boot and it asks you to boot to CD, press R for repair, it will try to repair your OS, and if it is an OS problem ,then it will boot once again... If not you can try formatting your HDD and reinstalling windows...
4helpful
Down load pics
you must download the animations from the JVC website or use their PiCT application to create your own
get a blank cd-r, and just burn a normal data cd with the files on it (i think they are .flv files? not sure)
when you put the cd in the reciever, go to the menu > PiCT > download movies/pictures
hope this helps :)
Alesis MasterLink ML-9600 Logo
Top Alesis Televison & Video Experts
Ekse
Are you an Alesis Televison and Video Expert? Answer questions, earn points and help others
