Can't get no heating to come on although the hot water is fine. when i put the boiler in test mode it works fine but then after the 10 minute test time it switches off again. it isn't displaying any fault codes either...help anyone???
SOURCE: Is it possible to bypass the timer clock on the ferroli optimax he 38c
I don't see why not, just keep a eye on it, and run it only when you are using it. shut it off when not in use !!! stay clear of the pop off valve when checking it !!
SOURCE: ferroli optimax 31c
Here is a link to the manual.It shows fault codes.
http://www.ferroli.co.uk/Product_Documentation/Domestic/Optimax_HE_31_C_Manual.pdf
Please rate this solution.
SOURCE: fault code ( nocn ) on a ferroli boiler
if nocn is on the time clock then check the wiring to time clock and if all good then it is the time clock at fault and will need repleacing
no i don't think so mike all the valves, pipes etc are underneath the boiler. the radiators come on fine in test mode but it just shuts down after that....
