Question about Sony HDRCX110 Camcorder
Hdr-cx110 ... blinking error code E:61:00:00 auto focus doesn't work...
The focus is blurred and there are some point where focus will be adjusted but can not make zoomin or out.
Posted by miyofa82 on
  • miyofa82
    miyofa82 May 10, 2012
    Possible solution: view linkhttp://www.myksvc.com/camcorder/sony-hdr...
    Sony Handycam HDR-CX100, it was focus error, flashing E:61:00 in lcd screen, most common cause of this error is focus motor shaft fell out of the motor mount or focus lens fell out of the shaft. but this camera has different cause, the focus motor & the focus lens were physically sitting in right positon, but motor did not turn smoothly when I rotate it by a finger, so I cleaned, oiled & greased it. finally worked.
1 Related Answer
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: sony video camera hdr-cx110 ...
How I fixed the E:61:00 on my Sony DSC-P71 digital camera.
Symptoms :
· After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
· Camera would extend the lens but not be able to focus on anything past 8 inches or so.
· Zoom in and zoom out would not work.
· Playback mode and the Setup mode was not affected.
A Picture of the E:61:00 Error Message
Solution :
This may sound crazy and this has not happened since I did this but here is what I did to get rid of that error message. I have not had that problem since but here was my steps:
· Turn the camera off
· Hold the camera face down over a hard surface (Like you are going to take of your desk) with only about half an inch above the surface.
OR reference the video files below for an alternate method.
· Turn the camera on
· Let the lens extend into the hard surface, don't let it extend all the way. Mine retracted slightly and then tried to extend again (let it extend the second time).
· Lift the camera away from the hard surface and notice that the error message is gone.
Posted on Sep 09, 2011
2answers
Sony video camera hdr-cx110 ... blinking error code E:61:00:00 auto focus doesn't work... I can see inside the lens and see movement when I use the zoom in and out ...
Hi Hedonismious,
If the camera is under warranty the best option would be to get it repaired for free via the service center.
Either they will repair it or replace it.
From the error code , it seems to be the zoom lens malfunctioning which you cannot repair by yourself and the error in itself means that you need to get in touch with the service center.
It's a chip level fault or a firmware fault which SONY authorized center can deal with.
What you need to do , i contact the service center and just inform them about the error code that you are receiving , and they will come to know as to what is the problem and direct you to appropriate department and method to get this problem resolved
I would also like to caution you , that you should not attempt anything on your own in this situation because it may result in further damage to your camcorder.
Hope this helps ...:) Let me know in case you have any queries.
tip
Convert and Edit Sony HDR-FX7/XR150/CX110 Series to Mac, iMovie, FCP
Sony HDR series Camcorders are High Definition Models, which store video in AVCHD MTS/MPEG-2. As a kind of popular HD camcorder, Sony HDR series own several hot family members including Sony HDR-XR150, HDR-XR500V, HDR-CX110, HDR-CX150, HDR-FX7, etc. Sony HDR series Handycam is lightweight, recording in high definition with good video quality, easy to use.
If you decide to select one, now, the following list of Sony HDR Series Camcorders you can check:
Sony HDR-CX Series: HDR-CX100, HDR-CX110, HDR-CX120, HDR-CX150, HDR-CX300, HDR-CX500V, HDR-CX550V, etc.
Sony HDR-SR Series: HDR-SR12, HDR-SR11, HDR-SR7, HDR-SR100, HDR-SR200, HDR-SR10E, HDR-SR12E, etc.
Sony HDR-XR Series: HDR-XR100, HDR-XR150, HDR-XR200, HDR-XR350V, HDR-XR550V, HDR-XR200E, etc.
Other Sony HDR Series: HDR-HC7, HDR-HC9E, HDR-FX7, HDR-FX7E, HDR-UX10, HDR-UX20, HDR-AX2000, HDR-TG5, HDR-TG5E, etc.
(Some of Sony HDR Camcorder Compatible with iMovie' 09) http://support.apple.com/kb/ht3290
Owing to Sony HDR Handycam recording video in AVCHD MTS/MPEG, or miniDV, for Mac users, you cannot directly import these MTS, MPEG, miniDV video to Mac to edit with iMovie, FCP, etc.
If you want to convert and import Sony HDR video to Mac, how to do that?
Sony HDR Video Converter for Mac is the best solution to tansfer Sony HDR video like AVCHD MTS, MPEG2, miniDV, etc to MOV, MP4, M4V, 3GP, H.264 for Mac. With this AVCHD Converter for Mac, you can easily convert camcorder video such as MTS, M2TS, TOD, MOD, MPEG, etc to MOV, MP4, AVI, 3GP, FLV, MPEG-4, MP3, etc for Mac, iMovie, Quicktime, iDVD, FCP, FCE, Adobe Premiere Pro, iPad, iPod, iPhone, Blackberry, Youtube, etc.
Quick Guide to Convert Sony HDR Video to Mac, iMovie, Quicktime Step by Step
Step One: Import Sony HDR Video
Click "Add File" to add your Sony HDR AVCHD MTS or MPEG-2 files to Mac AVCHD Converter after you launched it. You can upload several videos one time.
Step Two: Set Output Video Format for Mac
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, Quicktime, iMovie, FCP, FCE, etc.
Step Three: Convert Sony HDR Video
Click "Start" button to convert Sony HDR video like AVCHD MTS/M2TS, MPEG-2, miniDV files to Mac. After conversion finished, you can enjoy converted Sony HDR video on Mac or edit these videos with iMovie, FCP, Adobe Premiere Pro, etc.
More Tips: How to convert and import Sony DCR Series video to Mac, iMovie?
How to convert/import Panasonic HDC series to Mac and edit Panasonic HDC Video in iMovie, FCP?
on Oct 28, 2010 • Computers & Internet
tip
Sony HD videos Review:Sony Cyber-shot DSC-TX7 and HDR-CX110 Camcorders and...
Camcorders and cameras could be the electronic devices that you would never get rid of. There are special events and memorial moments like wedding, sports, birthday party, a long trip in South Africa and so on.
While choosing a camcorder with less than $500 bucks, what models would you consider? There are popular brands like Sony, Panasonic, JVC, and Canon.
Each manufacture promotes products with different attractive points. Here I would like to take a look at two new release Sony camcorders, Sony Cyber-shot DSC-TX7 and Sony Handycam HDR-CX110, for entry-level consumers as examples.
Sony Cyber-shot DSC-TX7 could be taken as one of the ultra-compact camcorders with the light weight, while Sony Handycam HDR-CX110 is general camcorder. Both AVCHD camcorders are wonderful with HD recording at 1920x1080, and there are bundled tools for some camcorders. However, the Mac version of PMB portable only seems to support Cyber-shot DSC-TX7 now, and there is no news for Sony HDR-CX110 yet. To make full use of AVCHD camcorder, you can use AVCHD MTS/M2TS converter for easy video editing and importing to software like Adobe Premiere, Avid.
Let's have a look at the comparison chart for the two models:
Even though Sony HDR-CX110 is more expensive and larger than a mini-camcorder, this model includes a 25x zoom lens for better video and picture. However, Cyber-shot also includes higher effective sensor resolution to 10.2 megapixels. The AVCHD videos with MPEG4 AVC/H.264 video codec provide high quality. Since the videos are recorded with interlace, while playing AVCHD MTS/M2TS videos on computer, you shall remember to deinteralce .mts for smooth playback.
If your eye is not that critical for images, the two models Cyber-shot DSC-TX7 and HDR-CX110 could be your first camcorder for HD video. If you are looking for a higher quality camcorder, a higher cost will be ready for around a thousand bucks like Sony Handycam HDR-XR520V, HDR-CX550V, Canon Vixia HV30 or other AVCHD camcorders. Fortunately, the AVCHD camera MTS converter from Aunsoft Studio supports the AVCHD camcorders listed above, and you can play and edit HD videos on both Windows and Mac.
on Aug 10, 2010 • Cameras
2helpful
2answers
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
The picture are blurred and even in 10MP mode the resolution is very poor. the pictures lack complete sharpness.
Try resetting all the functions on your camera first. If that still doesn't work then you probably have a problem with the auto focus unit in your camera. Contact an authorized Nikon service center for further information.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
With my camera on Auto sometimes I get clear pictures and other times they are blurry.
Hi boutep,
The auto mode will not necessarily work when there is hand shake , it seems that , it will remove slight hand shakes and blurs , but that's not what it's meant for.
The auto mode is like a sensor to the surroundings and then adjusts the camera exposure and color settings accordingly.
Therefore remember whenever you take pictures , not to move the camera and it's always better to focus an image first by half pressing the button and then when the image is focused and green dot is coming on the screen , you go ahead and press the button fully.
Hope this helps ..:) Your feed back would be appreciated.
1helpful
Have a HDR-CX110 code E:61:00 can hear motor humming want focus not even a year old
If it is less than a year old then it is still under warranty. Take it back to the store you bought it from.
I have a Cannon EOS Rebel xsi SLR camera. When I look through the viewfinder the image is blurred. IT worked fine the last time I used it, but this time it is blurred and I haven;t been able to correct...
Two possible situations. It might be that the lens focusing system isn't working. Try focusing by hand (turn the lens manually) If the image moves through a point of sharp focus, then you have a lens or focus motor problem.
More likely, you have improperly adjusted the diopter. There is a small, circular wheel on the right side of the viewfinder, toward the top corner. It is sometimes covered by the rubber viewfinder hood so you might not notice it. This adjusts the diopter correction in the viewfinder and if it's set wrong, nothing will ever look in focus. The pictures would be fine, but since the diopter is a correction for your eyesight, the viewfinder will be out of focus.
Viewfinder out of focus
Hello nikkid, E..:.. indication means that you should contact the nearest Sony Service. Possibble cause of this error can be the optical unit itself. Best regards, Arpad
Sony HDRCX110 Camcorder Logo
Top Sony Video Cameras Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
