Question about Stanley Garden
Stanley 223230X692A owner's manual
Pull cord yanks arm back when trying to start
2 Related Answers
Anonymous
  • 155 Answers
SOURCE: Craftsman 4hp pushmower motor is jerking backwards
sounds like the timing is out i would check the flywheel key it may be sheered off
Posted on Jul 27, 2009
mikehowy
Michael howard
  • 177 Answers
SOURCE: When yanking on the pull cord to start engine
Im guessing that you have started it before, so I guess , check that its not flooding ,pull air filter out see If you can see heaps of fuel in the bottom hole ,if you do take spark plug out pull cord a few times without holding start cable or you will catch on fire replace spark plug try starting ,no start still flooding take it to a lawn mower place ,float may have a hole in it , if not flooding, on the bottom of the cardy one brass nut , four holes find them clear then, start also a brass pipe going into the center of the carby is probable blocked
Posted on Jun 18, 2010
Trouble shooting stanley 6.5 26 in cut. i cant pull cord to start. removed plug and when put back same problem
Try tilting the machine backwards for a few hours. It may be oil on the piston that is causing a vaccum
May 03, 2017 | Stanley Garden
Stanley chipper shredder pull cord is stuck. It has a back-up electric start, which also won't work. The engine sounds frozen.
sounds like something may have jammed the engine! it may be worth taking the pull cord of and then trying to turn engine with a pair of plyers
Apr 08, 2017 | Electric Garden
My cord wont rewind
The rewind tension spring may be broken or fully extended. Try to yank hard on the cord and pull toward you with some force. Pull until the line will no longer come out and if it won\'t recoil then it needs to be repaired.
Apr 01, 2014 | Electrolux Vacuums
Yard Machine modelY28 P00 item41cdy28gooo,starts and runs for a minute or two and dies. Cannot get it to restart.
sounds like stuck float or dirty carb pull bottom off carb and clean . be sure to check float moves up and down freely
Jan 20, 2018 | Yard Machines Gas String Trimmer Y25
Revs racing on Vanguard twin 18hp
down load the manual pdf file from B& S on the model you have.
Jan 23, 2013 | Tools & Hardware - Others
I have a Husqvarna 455 Rancher chainsaw with a 20"
Part of the cord must of got into the clutch if its not the retracting mechanisem or spring you are on the right track. The olny question i have is if its a 2007 why did the cord fail so quickly. rebuild it you will find the answer I can't see it and you sound vary capabale of fixing this
Dec 19, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Owner manual
Most all manuals are available at www.bostitch.com, look for support tab, then select service parts and documents. Find your model number in the pull down list and finally select usage manual.pdf, enjoy.
Jun 18, 2010 | Stanley Bostitch Coil Framing Nailer
Jun 18, 2010 | Mtd 22" Yard Machine Push Mower
Garden Logo
144 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
