Hi have hotpoint aquarius tumble dryer just fixed bolt to rear of drum but now have NO HEAT any suggestions please
Drum turning cycle going but no heat at all, not sure if when fixing bolt at back of drum that something was shifted out of place that turned of heat element, help!
at wits end cant afford service call out so need to fix this myself help pleaseat wits end cant afford service call out so need to fix this myself help please
You can't post conmments that contain an email address.
Thanks steve but could you expand on that, is it fixable and if it is can you advise how?Thanks steve but could you expand on that, is it fixable and if it is can you advise how?
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
Check on the back of the drum for a thermal fuse or relay. Common fault on tubledryers is no power to heating coils becuse of blown fuse or most likely the relay to heating coils is dirty. have to be cleaned about every 2/3 years depending on use.
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
