Trying to find out which wires are for rear speakers
See the wiring diagram on page 2 of the installation guide.
SOURCE: wiring speakers
For a Sony CDX-CD7000X, the connection would be:
and the wirings would be:
The images were cropped from the unit's spec sheet.
Hope that this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: I need a color code for a Sony Xplod CDX-GT23W.
Guessing that you don't still have the owners/install manual.
On the back of the head unit there should be a group of unused/unconnected wires (with any luck they will be marked), one or more might be an amp turn-on or power antenna lead, so I suggest (with the unit turned on) testing each wire with a DC voltage tester so as to identify and separate any leads supplying 12+ volts. the remaining group will consist of speaker leads. Trial and error testing will determine the proper L & R rear speaker leads.
Good luck
Aduz
SOURCE: hi i have a sony cdx L280 Player can you tell me
hi
white and white/black- front left
gray and gray/black- front right
green and green/black- rear left
purple and purple/black- rear right
john
SOURCE: need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
SOURCE: i need to know the speaker wire colors for a 1989
best thing to do is undo the door pannels and radio and check for yourself
