I have a server who has not closed thier shift. Cannot figure out who the server is to close it. Can the open shifts be found anywhere?
Try running the SHIFT SUMMARY report for the day in question. this might tell you.
[email protected]
Please return and give me a favorable rating if this helps or is of value to you.
Feel free to email me with more details if need be.
The automatic transmission shift lock control switch
The brake to shift relay
The rear integration module (RIM)
With the ignition in the ON position, battery positive voltage is supplied to the brake to shift relay coil. When the RIM energizes the brake to shift relay, the brake to shift relay switch contacts close suppling battery voltage to the automatic transmission shift lock control switch. The circuit continues through the normally --closed switch to the automatic transmission shift lock control solenoid. The permanently grounded solenoid is energized. This locks the shift linkage in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open. This causes the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
Shift Lever Does Not Move with Brake Pedal Depressed ?
Found the Culprit. The owner (who swears he has never even logged in) had a shift open. Never found it in any of the reports but logged in as him and found the shift open. Thanks for the responses
