Question about Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Posted by Joe Finn on
    Top Expert:
  • Sony Master
  • 76,407 Answers
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
Posted on May 03, 2012
5 Related Answers
Anonymous
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Anonymous
  • 4 Answers
SOURCE: sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Posted on Jan 01, 2009
    cathim
    SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
    Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
    Posted on Dec 01, 2008
    Lashawn Robinson
    • 1153 Answers
    SOURCE: tv blinks twice
    ak-blinking needs caps and resistors changed check Q601,Q602,T603
    Posted on Aug 22, 2007
    Ivan Godzharov
    • 112 Answers
    SOURCE: Sony FD Trinitron WEGA KD-27FS170 TV red light
    do you have the 13 volts can you see with the oscilloscope the input Driver pulses are they there
    Posted on Sep 24, 2010
    3 red blinks
    Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. To get more details, http://electronicshelponline.blogspot.com/ Blinking codes details to Sony Trinitron TVs are given.
    Nov 17, 2013 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Sony kv-34xbr910 wont turn on
    I have sony 34 XBR Tube trinitron HD TV. We are not using the TV because it keep giving us 6 blinks and does not turn on
    Apr 26, 2008 | Sony FD Trinitron WEGA KV-34XBR910 34" TV
    Turn on my Sony FD Trinitron WEGA KV-32HS510 32" TV, you hear a click, and then it blinks 3 times pauses and repeats.
    Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. This is the fault with 3 blinks. If you wish to get more, check the site linked here.http://electronicshelponline.blogspot.com/ Pull up previous posts, either by brand search, or view it in Mosaic / Timeslide / Flipcard option.
    Aug 18, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
    Sony TV turns off immediately after turning on
    Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Check this link to get more details about Sony Blinking codes.
    Jan 13, 2013 | Sony FD Trinitron WEGA KV-20FS100 20" TV
    Tv wont turn on and the stand by blinks 2 times pulse 2 times sony Trintron KV-24FS100
    1. Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. This is the fault. There is over voltage from the voltage regulator section inside. You have to check out the reason for that. In most cased, the will be due to some loose solder terminals at this section.
    Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there. Check the site, and see whether it can help you.
    Nov 25, 2012 | Sony FD Trinitron WEGA KV-24FS100 24" TV
    Sony kv-40xbr800 blinks two times
    Jun 09, 2012 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
    Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
    Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
    Tv in standby mode blinks 2 times then pauses and blinks again
    Hello
    Check your TVs power supply regulator section for any loose sodering points in it. The regulated voltage comes from it is more thatn normal. Check out all the soldering terminals. It is best to resolder all the suspected solder terminals by applying a little more solder, without making any solder bridge short in between adjecent solder points. The fault symptom as reported by sony is:-Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
    Check for any short circuit in the secondary section of the SMPS power supply section. Check the horizontal output transistor for collector to emitter short.
    OK.
    Aug 07, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    I cannot turn on my tv but it blinks for two times then turn off, it is happening without me touching anything. please help
    • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
    Nov 25, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    SONY Trinitron TV doesnt turn on
    TWO Blinks
    Nov 09, 2017 | Sony KV-27V40 27" TV
    Sony FD Trinitron WEGA KV-30HS420 30" TV Logo
    670 people viewed this question
    Top Sony Televison & Video Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Ekse
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
