Looking for a parts layout diagram
SOURCE: Mystery part to early 1950's Hobart N50G Mixer; serial number 997185
is this like a brass bushing? whats it made out of?
SOURCE: Mystery part to a 1950 Hobart N50 Mixer; serial number 997185
Go to www.hobartservice.com, register, then go to select "food machines" in the Product Group, then "mixers"and look for the Discontinued Products, then find the N-50 mixer drawings, they are all there, even the old ones. Look through the "exploded" drawings for your extra parts. It seems to me that the tech who put this together should know if they belong to this mixer or not. Does he work for Hobart? Or is he a repair person who states that he knows how to repair Hobart products. If he does'n't work for Hobart, these parts may have been on his bench BEFORE he looked at your mixer. A true Hobart Tech has access to specs on ALL models and the ability to access the Service Manuals. If you find this solution helpfull, please rate it. ricardok45
SOURCE: more info re: n50 hobart mixer
Judy. Hobart was sold to Illinois Tool Works (ITW) several years ago. The Kitchenaid product line was sold to Whirlpool Corp. several years ago too.
The new N-50 mixers have a motor that is designed by Hobart, but no longer built by Hobart. Last year Hobart began out-sourcing approx. 12-15% of their componnents to Asia. Their parts catalog does not show anything but metal gears. I suspect the new motors have been built in Asia. Wattage is not the output of the motor, but how much power it takes to run the motor and is no indication of how much power goes into your mixing bowl. The true measure of mixing power is horsepower. The N-50 motors are rated at 1/6 HP. Wattage claims by mixer manufacturers is a complete snowjob, and they all do it. Consumers have no protection as a result of this policy. It is a marketing ploy to make you believe that this indicates output power. Shame on all of them! Most componnents of the new N-50's are still manufactured in the USA.
I see that you've done some homework on Kitchenaid Mixers. I wish I had before I bought mine. Yes, they have a plastic transmission housing, and yes, they fail under strong loads demanded by bread dough and stiff cookie dough mixtures (my HD Professional 450 watts failed 5 months out of warranty, after only 30 uses making bread). Go to the www.consumeraffairs.com website and search for Kitchenaid mixer problems and reviews and brace yourself for a shock.
My mixer failed on Oct. 28th. and I had to fight tooth and nail with Kitchenaid to get them to re-imburse me for the cost of the parts that were destroyed by the housing failure. Here we are in 2009 and I'm still waiting for one more part. Kitchenaid parts take at least a month to arrive (in my experience).
I didn't do the research on mixers until mine failed. Since then I've purchased an older Hobart N-50 (with a motor BUILT by Hobart), and this is what I recommend you do, as it will save you much grief down the road. Mine was manufactured in 1990 and only needed. re-greasing to make it like new.
You can find them often on eBay but will have to buy without trying them. Try to find one that is newer rather than older, as a rebuild will get very expensive. I got mine from a Rest. Equip. Wholesaler and was able to try it out in all gears. The previous post (solution) was correct in saying that you should look for one that has a black knob on the shifter handle, this will be a newer one as opposed to an ancient one with an all metal shift lever and potentially worn out innards. If you find one, take it to Hobart, or a Hobart tech can come to you (check service rate) have the unit cleaned, inspected and re-greased. Sit back and take comfort in the fact that these mixers were built like a tank, and will probably outlast you.
Most of all. Good luck, and happy hunting. ricardok45
SOURCE: I suspect my D300T Hobart Mixer has a broken shaft
Hi. Go to hobartservice.com, register for free. This will allow you access to the parts files for your D300T mixer. Download them. When you begin your disassembly, take a photo of every piece that you remove, lay these pieces on a piece of cardboard or something suitable in the order that they were removed. This will help you greatly with your project. Good luck! ricardok45
SOURCE: wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
