I'm no sure what you're asking. Do you mean that it goes directly from low to high immediately when you turn the dial(I'm assuming it has a dial, I haven't looked it up) or push the up or down button?
Answer is, if rotary, a bad rotary switch, or in both cases, a bad microprocessor or electronic volume.
SOURCE: Kenwood KA-994 Amplifiler no sound from rear speakers.
SOUND FROM YOUR SURROUND SPEAKERS COMES BY BECAUSE OF PROCESSING THAT TAKES PLACE IN YOUR SURROUND CIRCUITS. IF THE SURROUND MODE IS ACTIVATED AND U GET NO EFFECT AND U SURE YOUR SURROND SPEAKERS ARE OPERATIONAL AND FULLY FUNCTIONAL. THEN THE PROBLEM LIES WITH YOUR SURROUND DECODING IN YOUR UNIT. REFER TO QUALIFIED SERVICING AGENTS.
SOURCE: KENWOOD Power Amplifier
The power amp does need an imput signal ie. tuner, cd , and such to play. You can use the power amp with the other equipment.
Good Luck
BIG RED
SOURCE: Kenwood KA-994/KM-894 amps. I am
If you have the existing woofer get one that has the same size and impedance, It may be 8 ohms impedance approx. 200mm dia. to fit inside the existing enclosure.
