Gateway NV55C26u Notebook Logo
A
Anonymous Posted on May 02, 2012
I forgot my user password to my gateway laptop
Anonymous
Level 2:
Novelist:
  • Expert 112 Answers
  • Posted on May 03, 2012
Anonymous
Expert
Level 2:
Novelist:
Answers
112
Questions
0
Helped
31108
Points
184
You can bypass Windows User Password, follow the steps below: Step 1: Download Bypass Windows Password software and install it.
Step 2: Burn a bootable Windows Password Recovery CD/DVD or Windows Password Recovery USB flash drive with the program.
Step 3: Reset Windows Administrator Password to blank with the burned CD/DVD or USB, then bypassing windows password and regain access to your locked computer.
1 Related Answer
axesword2000
PC repairs
  • 53 Answers
  • Posted on Feb 13, 2012
SOURCE: when i turn on laptop it says hard disk locked enter user password but i forgot it
If this is the BIOS password pull the CMOS battery for a couple minutes, then replace...it should reset the BIOS settings...if its only a hdd password and u forgot it u can contact local technician but that might cost u
Bought a laptop at auction but don't have password to open up
Hi
Password for user,
1- if its windows 7 then do two times ctrl +alt+del then enter user:administrator without password
2- if its windiws 10 then see this link
https://youtu.be/P50PQwiYNec
Hope this can help you.
tip
How to Reset Gateway Password?
How to reset Gateway laptop password? I forgot my PC password Gateway Windows 7, I want to unlock laptop password urgently! Can you help me recover my lost power on password for Gateway? Now, we together share some ways to remove Gateway admin password.
Optional 1: DIY a CD/DVD/USB password reset disk instantly to recover lost Gateway password
The method is the most effective solution to get out of Windows password problem. It just needs burn an .iso image file to one of these media. Now, take one of most popular Windows Password Recovery tool as example:
A. Download Windows Password Recovery and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible PC;
B. Boot the burned CD/DVD or USB Flash Drive from the PC lost password;
C. Reset a new Gateway password.
Whatever for Gateway Windows 7, Vista, XP, Server 2000, Server 2008, etc. the above Ainorsoft Windows Password Recovery has its different versions to suit for these OS.
Optional 2: Gateway password recovery disk helps remove lost laptop password
It is the most convenient way to retrieve Gateway PC password and while, is maybe suitable for little part of computer users. The Gateway recovery disks should be created once our Windows account is created. Also, one account password responds to one password reset disk. Take Gateway Windows 7 as example:
A. Insert a CD/DVD/USB Flash Drive into the driver.
B. Click Start - Control Panel - User Accounts and Family Safety - User Accounts.
C. On the left pane, select "Create a password reset disk" - "Forgotten Password Wizard".
D. Click "Next" and follow the Wizard to create password reset disk.
Now, the Gateway Windows 7 password recovery disk is created. When we need break Gateway Win 7 laptop or notebook password on the login screen and input an incorrect password, click "Reset Windows Password" and insert the password reset disk. The Password Reset Wizard will help you create a new password to override lost Gateway password.
Optional 3: Reset Gateway password by accounts with administrative privileges
Accounts with administrative rights or the default and built-in account can help us to remove Gateway password. Take Gateway Windows XP as example, there is a default Administrator account. We can use it to unlock locked account if this built-in account is still blank or accessible.
A. Press Ctrl+Alt+Del twice when PC starts and then input "Administrator" in the username field and leave the password filed blank at the classic login screen. Press Enter and login PC.
B. Start -> Control Panel -> Administrative Tools -> Computer Management -> Local Users and Groups -> folder Users
C. Right click the account user name which password was lost, and then click Set Password -> Reset password -> keep New Password and Confirm Password blank.
D. Right-click locked account and select Reset password.
E. After finished, restart PC and login.
Optional 4: Ophcrack Windows Password Recovery software
Ophcrack is a free Windows password recovery tool which only works for passwords with less than 14 individual characteristics.
A. Download the Ophcrack LiveCD and burn its .iso file to a CD on an accessible PC.
B. Insert the CD into the locked computer and restart it.
C. When computer starts, we have to press the correct key to enter the boot menu.
D. After select the drive that the CD is in at start menu, do as the following instructions.
If we forgot Gateway laptop password and need Gateway password reset, we can easily reset Windows 7, XP, Vista password on Gateway PC or netbook with the above 4 optional methods.
Source: http://windowspasswordrecovery.net/article/gateway-password-reset.html
on May 06, 2011 • Computers & Internet
I forgot my password
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
There is a free boot CD called Hirens. This one command prompt only.
Forgot password on a gateway laptop
Forgot gateway laptop password? Don't worry about it ,you can use Smartkey Windows Password Recovery to help you to reset forgotten password, and you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Forgot my password on Gateway laptop PC- model NV52L08u operating system Windows 7- Please help- ROGER
Hi
You need to use the Password Recovery Tool to reset the password of your computer.
You need to view the complete steps. Click Here to Get the software and the Procedure.
In case if you have any trouble get back to us in Fixya.
Thank you
How do I unlock I locked myself out of laptop unable to login
Which Password? Bios Password?Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista?Windows 7?OK,if you are running Windows 7, Microsoft tightened security on it so you've gotto have a password reset disk which 99% of the people who own laptops withwindows 7 fail to do. It should be one of the first things you do whenyou buy the laptop. Otherwise, you're faced with reinstalling theOperating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on andimmediately start hitting the F8 key repeatedly until you see the Safe Modeoption. Select SAFE MODE and let the computer boot up. When it getsto the User Login screen it will show the Administrator userid and the useridfor which you forgot the password. Sign in as the Administrator(hopefully you didn't put a password on it and forgot it too). Once thedesktop appears it will look different, the screen will be darker and the iconsbigger, but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgotthe password. Select the option to REMOVE PASSWORD.
Reboot your machine.
When i turn on laptop it says hard disk locked enter user password but i forgot it
I forgot my gateway laptop password and can only get on guest. how do get in with out using a disk or usb?
restart the pc and then as soon as the black screen appears keep pressing f8 till the boot menu comes up, choose safe mode. when windows loads up in safe mode Login as Administrator then click start > control panel > users click on your account > click remove password. Restart pc and log in to your account
1helpful
I forgot my password to log on to my gateway laptop model # mx3560
Try loading computer in safe mode. You can do this by repeatedly pressing F8 upon start up it will take you to an advanced options menu. Within there select safe mode by using arrows to navigate up and down. Then press enter when safe mode is highlighted. When it loads it will look alot different DONT FREAK OUT! :) Then there will be a couple of user accounts u can try logging into them and leaving the password field blank. Some times there are accounts w/o a password and will allow access into computer. From there you can create a new password within the control panel & user accounts
Forgot my password how do i unlock my laptop
Start in safe mode...press f8 at start up.Select the admin account.Go into the control panel...select user accounts..Select the profile thats locked and select remove password.Reboot ....all should be well
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
