SOURCE: canon ir c 3200
It is a fuser heat error. Try to reset the machine from the error code. If problem persists you have the check the fuser for damage. Could be a thermister, thermoswitch, or faulty heaters. To clear error, service more function/clear/error/ok/ exit service mode and cycle power.
SOURCE: HAVE CANON IR C6800 WITH THE FOLLOWING ERROR CODE... E000001-00ff
It is a Fuser error code .
Could be a poor connection with the draw connector on fixing feeder unit.
Try shimming all three connectors on the fuser draw side can resolve the
issue. Another thing to check is the upper fuser roller for flat spots
this can also cause fuser error codes
SOURCE: error code E000001-0003 canon clc2620n
it is a fusing/fixing error try this on the control panel press * with head 2&8 together *with head >copier>function>clear>err>ok turned off/on the machine hope this help
