Dab radio has stopped working , Cd player and ipod docking is fine
You need to tunr the power off at the wall socket. Leave the unit off for at least 5mins. Then whilst holding the power on button on the unit down, turn the power back on at the socket, keep the power button depressed for at least 5secs. When you release it you should see -----------------, in the display. The unit has just been reset to factory mode. All features should now be present again. Hope this helps.
Thanks Chris I was quite concerned. Your solution fixed my problem. Brilliant
spot on
So helpful, thanks
Thanks a lot - it works
This problem may re-occur if you have a weak reception signal.
Very useful. DAB tuner had stopped responding. Your solution has worked. Thank you.
Thank you i know this answer was given 10 years ago but it has worked for me on my old SA-PM602 as the DAB had stopped working thank you so much
Chris, you are a genius! The DAB+ stopped working on my SC-PMX82 (2018 vintage) and hey presto your fix has worked. Many thanks for posting the advice.
SOURCE: just bought a panasonic home theater sys.. cant
try to look for the settings that the source will be in ipod dock, if there is.
SOURCE: the dab radio has stopped working on my compact stereo system
You need to for cold solder spots on the pcb.
