Question about Samsung SyncMaster 793MB 17" CRT Monitor
Sir I have a DELL desktop CRT monitor which model no is E772p.It is not working .I opened the monitor and checked. I found that switching mosfet was short in power supply.It was taken out from the board.But i have lost the mosfet.I want to know the mosfet number.Gate driving ic is used. which is TEA5045AP.
Posted by prasad on
John Cunningham
  • Samsung Master
  • 6,771 Answers
You will need a service manual to get the correct part number, I tried to cross with my NTE data base no luck, went into ebay site punched in the original numbers came up empty.
Posted on May 03, 2012
5 Related Answers
Anonymous
SOURCE: problem with opening monitor cover
to remove the back cover of samtron 56 v monitor is very simple.
locate the 2 bottom screws of the cover, remove them. pull slightly back the cover holding the bottom and about half an inch gap will be seen. insert a flat screw driver straight down through the upper side hole with your left hand and hit the head of the screw driver with your right hand. a slightly big sound is heard and that side is disengaed. repeat he same with the second hole. and you have done it. try.
Posted on Jan 25, 2009
Anonymous
SOURCE: SMPS IC for Samsung 753S Monitor
Can you help me about SMPS IC DP704c on [email protected]
Posted on Mar 03, 2009
sys_admin
Milind Shetti
  • 829 Answers
SOURCE: switched from crt to lcd, no display!
You need to install the Display driver shipped or downloaded from net.
Posted on Mar 31, 2009
Anonymous
  • 131 Answers
SOURCE: To open the Samton 45Bn crt monitor
turn off power.
Get a long philips screw driver and remove the base and all fixing screws. some are hidden behind blanking plates and the com off with a sharp knife and a getle lifting at the join.
After all screws are removed the lie the screen downwards and start to pull away the backing.
you should get the case apart easily.
You must be aware of the tube holding a full charge at its end. DO NOT touch this at any point. The only thing you should try to inspect is the fuse or adjustment to the focus slant contrast etc.
AndystUK
Posted on Aug 30, 2009
Anonymous
SOURCE: SAMTRON 56V 15 in.CRT A41DC IC PROGRAM
I have Samtron 56v colour monitor. It is not powering on. I have to press the switch several times to power it on.Otherwise I have to slap on it & then switch it on than only it starts.Please tell me if you have any solution for this.
THANKS
Posted on Sep 01, 2009
Does the older dell monitor e772p have built in speakers
The answer is no. this is an OLD Dell CRT monitor that does not have speakers.
Jan 29, 2015 | Dell Computers & Internet
My monitor keeps on showing the monitor menu and it automatically operates do anyone know about it??????????
I fit is in warranty please get a call logged get the Toll free no for your region on the official dell website ,
One of the menu switches is getting shorted automatically it has to be replaced .
Jul 17, 2013 | Dell E772p Monitor
My Dell Monitor E772P Control menu keeps showing on all the time and dont disappears plz tll how to get rid of this menu.
The menu should tell you to press 1 (or 2) to get rid of it. The (1) and (2) refer to the first two buttons on the bottom right side of the monitor.
Apr 26, 2011 | Dell E772p Monitor
Hi i gott dell dell e772p monitor menu button problem,so can u solve this problem 4m?
Hi as you informed that you have a menu button problem so let me know how old is your dell e772p monitor to proceed further
Mar 08, 2011 | Dell E772p (Gray) 17 in.CRT Conventional...
I have a deel monitor E772p its no open power fixed the error and call me
is hardware problem, the power supply is malfuntion, needs to be checked by a tech.
Aug 08, 2010 | Dell E772p Monitor
Mosfet check
1. Switch your multimeter to the Diode test position.
The following steps are for an N-Channel MOSFET.
Hold the Black lead to the MOSFET's source terminal.
2. Touch the GATE terminal momentarily with the Red lead.
3. Then touch the DRAIN terminal with the Red lead without touching the GATE terminal with your fingers.
The multimeter should show a low reading now. (The MOSFET is now ON)
4. With the RED and BLACK leads still connected to the DRAIN and Source terminals of the MOSFET, now touch the GATE terminal with your finger. The Multimeter should immediately show an open cct. (The MOSFET is now OFF)
This is a very simple way to test a MOSFET.
Jan 13, 2010 | Epson >>> IM800 DARK GRAY 733 MHZ CPU...
No power into my crt monitor samsung
first disconnect the path of EHT then check voltages if present then open H o/p transistor check it if faulty then replace it if not then EHT is faulty replace it also check IRF630 mosfet if faulty replace it
Nov 04, 2008 | LG Studioworks 563N 15" CRT Monitor
Samsung 953BW monitor alwyas goes to blank screen
first u will check the signal cable then check crt base [ if lot is arcking ok] replace crt base check filament volt,g2 volt,g1 vot .....etc,then u r chek 5v reg ic in supply out on smps,eprom chip and check H OUT transistor base voltage u r problem not solved about this information pls ask again to me may i help u.......
May 16, 2008 | Computers & Internet
Samsung SyncMaster 793MB 17" CRT Monitor Logo
110 people viewed this question
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
