Discontinued MX - 700 remote instruction manual
SOURCE: how do i change the settings on the lcd screen and how do i program my direct tv?
Here is the link to the owners manual: http://www.universalremote.com/resources/pdfs/MX-850OwnerManual.pdf
SOURCE: genesis mx-900
I have the same remote and need to reprogram the remote too.
Genesis X900 has anyone had any luck finding out how to reprogram this remote yet?
SOURCE: can't program mx-700 remote
Hello there,
I just had the same issue and solved it- its pretty easy as it turns out. check out
http://www.universalremote.com/resources/pdfs/MX600manual.pdf
This is the previous model owners manual but it works. You'll want to program using the "learn" mode where you point the remotes at each other.
SOURCE: mx 3000 universal lcd remote
There are 4 reasons why your unit is behaving this way:
1. Charger is the problem.
2. The docking station is the broken.
3. The battery is broken or not accepting charge.
4. The actual unit is the problem.
It is very hard to tell which one is causing this to happen.
Let us do some troubleshooting first:
1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken.
2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken.
3. If the red power light is lit and the status light (right) is lit too, your docking station is broken.
4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged.
5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
SOURCE: Opening the MX-500 Remote Control
Use a small flat blade (screwdriver, or whatever) and pry around the light button. The bottom connects over the top so try to guide the blade in the crack then down and out. If you get an slight opening, stick a another small blade in to hold it while you continue to pry. It make take a fair amout of force to get the bottom part, start with the top.
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy. Setup code list and instructions to MX remote control is there.
