Question about Electrical Supplies
Kohler marine generator troubleshooting
Looking for a troubleshooting guide for Kohler 7.3 ECD Marine generator
Bill consigli
I have a kohler marine generator that shuts down when it reaches operating temp of 200/210 degrees. It runs for about 5 minutes. Already replaced impella and have sea water pumping through, coolant level is good. Any suggestions? Thanks
Posted on Jul 23, 2013
5 Related Answers
arealplumber
Better Plumbing
  • 33 Answers
SOURCE: Schematic
I looked for several minutes and this is what I found:
Kohler 13EOZD wiring diagram
I went to the Kohler site, entered the number and it cross referenced to the above number. The wiring diagram is on page 90.
Hope this helps!
Posted on Dec 05, 2008
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: Hello, I have a Kohler Marine Generator that says OC on the menu when I try to start it. Any ideas?
OC stands for Over Crank. How long does it take before the genset starts?
Posted on May 07, 2009
Sheldon Dedek
  • 912 Answers
SOURCE: kohler gas geset no fuel to carb
The pickup tube in the craft's fuel tank has likely worked loose and dropped into the tank. The generator lost its "straw" that it needs to siphon fuel through.
Posted on Jun 12, 2010
Sheldon Dedek
  • 912 Answers
SOURCE: 1975, 7.5 Kohler marine genset, runs only with the reset depresed
Can't search for a manual without model, type, serial, etc numbers...
A few things to take a look at:
1) Oil level / pressure sending unit. This is normally bypassed as long as the start switch is pressed. When engine starts, and switch is released, engine will die if sending unit is defective, or you are low on oil.
2) Exhaust temperature sensors. Older units were notorious for burning these up.
3) Cooling Water Temperature sensor. These cause trouble often, but mostly due to water pump impeller being eaten away by galvanic action and not able to pump water as effecively. End result is water temp higher than normal, which trips the switch, which kills the engine.
4) Alternator (generator) output not as it should. If output doesn't rise to proper level within a few seconds of engine start, the engine will be shut down.
5) Choke not working as it should
6) Bad fuel, bad fuel pump, clogged fuel filter.
Sheldon Dedek
  • 912 Answers
SOURCE: my kohler generator was running with out a flaw.
Double check your grounds at both the frame and the battery. Otherwise, your starter probably has a shorted field.
Posted on Jun 30, 2010
Testimonial: "thanks...will check frame ground"
I have a 1989 Kohler marine generator model 7.5R. It runs OK but not AC power.
The Kohler 7.5 R had a possible three different voltage regulators that could be used.
You need to check there first. Also if you can get it the service manual for these are tp-5110 Which will show you how to test the regulator o the bench. There was a 5 6 and 7 pin regulator that could have been used.
Sep 26, 2016 | Kohler Electrical Supplies
I have a Kohler 7.3 ECD generator with error code UVunder frequency. Restarted gen and it ran for one hour so I shut it off. What's the problem?
check the operating rpms
the rpms determine the voltage and frequency and can be adjusted at the governor spring setting
adjust it until the voltmeter reads the required voltage
set slightly above to allow for rpms drop under load
for example if 240 volts set around 250 volts and that will drop back to 240 volts under load
if 110 set around 115 and that will drop back under full load
both frequency and volts are dependant on rpms
Sep 20, 2016 | Kohler Electrical Supplies
I need the schematics for a Kohler marine generator model #7.5 R27
Contact Nixon Power Services in Charlotte NC or TN. They can help you with a manual. You would have to purchase it
Sep 11, 2013 | Kohler Electrical Supplies
Kohler gas geset no fuel to carb
Jun 02, 2010 | Kohler Electrical Supplies
Apr 20, 2009 | Electrical Supplies
Schematic
Hope this helps!
Oct 20, 2008 | Electrical Supplies
Electrical Supplies Logo
2,622 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
