SOURCE: Have a new belkin F7d2301
WIRELESS SECURITY ISSUES
Uninstall the Belkin Setup and Router manager from your computer
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
SOURCE: belkin password F6D 4230-4-V1
here is your manual:
http://cache-www.belkin.com/support/dl/man_f6d4230-4_v2000_8820-00034-a.pdf
if you can't login, you can reset to factory defaults
pushing at least 10 seconds the reset button
SOURCE: my F6D4230-4-v1 model belkin router is acting up. ...
just put a blankie on ur head and cry. that's what i did.
SOURCE: I have a new Belkin
If you dial back the security to WEP, does it connect?
Back to WPA though... when editing the Network Connections... Check SSID is correct. Mode "Infrastructure". IPv4 Settings is Automatic (DHCP). IPv6 Settings method is Ignore. Wireless Security is WPA & WPA2 Personal and the password is correct.
PS3, Xbox, Wii, Setup
http://fixhomenetwork.com/xbox-play-station-wii.php
