Question about Sony KP-53N77 TV
I have a sony kp-53n77 rear projection tv i cleaned the lenses but i still have alittle to much red how can i clean up the color
    Top Expert:
  • Sony Master
  • 14,553 Answers
Older projection set:
Not knowing exactly what it looks like I suggest two things: first in the menu look for convergence to see if it is off adjustment wise--it can be adjusted in customer mode to see if that helps.
Also either turn color all the way off (Black and white) to see what color the screen is with no color--if somewhat red you will need to turn the red screen control down--I can tell you where and how.
If screen is too red, red will be the prominent background color with color off or on.
Another easy way to LOOK is go to an unused video input---should only see "Input 1" for example in green and rest of screen should be black and not red to any degree.
Let me know with a comment here what you find.
Posted on May 02, 2012
2 Suggested Answers
6ya staff
SOURCE:
Big_Petey6
SOURCE: We need to clean our
Remove the back hardboard cover by removing all the screws and lifting the cover up and toward you.
Mirror will be above but usually doesnt get dusty. Try not to touch it if you can. Same with back of screen. If you have a spider web just use a soft dry cloth to wipe it away.
You will likely find the upward facing lamp lenses covered in dust. Clean these with a soft cloth moistened with glasses cleaning solution. Glass cleaner works too.
Posted on Mar 20, 2011
We need to clean our Sony KP-53N77. We have some spider webs inside the protective screen and our color is a little fuzzy. We have never had the mirrors cleaned. How do we access the areas to clean and...
Mar 20, 2011 | Sony KP-53N77 TV
I have a sony projection tv. Colors/piture not right
Replace convergence ICs and a 5 amp pico fuse on power supply. ICs are part number STK392-560.
Just be sure to use thermal paste on the ICs or they will self destruct in a short amount of time.
Jul 06, 2010 | Sony KP-57WS500 57" Rear Projection...
My sony tv model kp48s75 i dont want to do away with it ,but it has a blur and green out line
Have you Cleaned mirror and top of all 3 tube lenses, then adjust the screen and focus to each Tube R/G/B After cleaning go to menu then turn color OFF then adjust all 3 tubes as close as you can to a Black and white picture then turn color back on.
Feb 10, 2010 | Sony KP-48S75 48" Rear Projection...
I have a Sony KP-53VP0 Rear Projection TV Kinda Cloudy Picture.
take off the back of the tv and clean the lenses and the foggy picture will go away
Jan 14, 2010 | Sony KP-53V90 53" Rear Projection...
REAR PROJECTION TV SCREEN GETTING HARD TO SEE
Your TV requires service and cleaning of screen, mirror and 3 lenses (of CRTs) as looks dusty.
Below is an exploded view how to take off front beznet assembly of this TV to clean inside with moist cotton cloth.
Unplug TV before taking off front of TV.
Jan 26, 2009 | Sony KP-43HT20 43" Rear Projection...
Sony kp-46wt-500 tv help
if your set has auto focus try activating it if not you require a convergence alignment.
Apr 13, 2008 | Sony KP-53N77 TV
Sony rear projection tv KP-57HW40
Hmm, could you describe this better or post a pic? Try cleaning the lenses and disable SVM if it's on.
Apr 06, 2008 | Sony KP-57HW40 57" Rear Projection...
Kp-53n77 color 53
Try resetting to factory settings via tha manual at this link.
It will download onto your computer in PDF form.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KP53N77&LOC=3
Mar 11, 2008 | Televison & Video
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP 53S65 53" rear projection TV contrast issue
While the root of the problem is likely the picture tubes aging, I'm sure it would benefit from a cleaning and adjusting. After the dust is cleaned from the lenses, the screen controls could likely be lowered to get the blacks you desire. An experienced tech would be able to do this for you.
Jan 03, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
