Question about HP OfficeJet 4215 All-In-One InkJet Printer
How do you clean the print heads on an HP 4215 all in one?
Posted by Elise Antoni on
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: mirror image printing on a hp 4215
carrige belt problem
Posted on Jan 29, 2008
IB4G2008
Patrick Michaels
  • 3587 Answers
ok..and what is your question?
Posted on Feb 16, 2008
myob247
Georgia B
  • 1342 Answers
SOURCE: HP L7680 Print Heads need real cleaning!
If the ink has dried up in the nozzles try putting a wet cloth in the microwave to get it hot enough to produce a little steam and set the cartridge, nozzles down on the damp cloth until ink starts to ooze from the cartridge. May require a couple of tries. Try using the cleaning program again.
Be careful not to touch the copper contacts on the cartridges.
Posted on Apr 27, 2008
Anonymous
  • 34 Answers
SOURCE: HP Officejet 4215 will not print
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Posted on Apr 27, 2009
Anonymous
  • 71 Answers
SOURCE: HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Posted on Oct 20, 2009
How do I clean the print head of an HP 4215 all in one ?
i have hp products & get good assistance thru calling 800-474-6836
May 01, 2012 | HP OfficeJet 4215 All-In-One InkJet...
On my HP Officejet 4215, my black cartridge doesn't print. The cartridge is nearly full.
If you haven't used the black print option, as in to print without using the color cartridges, then the black print head may be 'gummed up'.
You can try to clean the print head using the 'clean' function, which may work.
You can also try to get the print head to work by using ammonia and hot water. If the cartridge has its own print head, you can use some hot water on a paper towel and set the print head onto the soaked towel for a few minutes. After it has sat for a while, gently dab it dry with another paper towel, and try to use it. If it works, you're done. If not, you can use ammonia to try to clean the print head using the same tactics as using water. Try water first, then ammonia.
If the print head is fixed in place, you have to remove the whole assembly from the printer, and then try to clean the print head using the same method.
tom
Aug 11, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP 4215 All in One - check right cartridge error
Hello!
As the manual of this device says
Check the print cartridge to make sure
you have properly removed its packaging. Being careful not to touch the gold-colored contacts or ink nozzles, make sure you have gently pulled the pink tab to remove the plastic tape.
Here is the link to a manual of this device. Hopefully, it will help.
http://manualsbrain.com/en/manuals/1174050/?page=154
Jun 23, 2017 | HP OfficeJet 4215 All-In-One InkJet...
Officejet 4215 not printing
It could be an empty/dried up cartridge depending on how old it is. If the printer just feed the paper straight through without trying to print(i.e. the printing head is not moving), then it is most likely a configuration problem.
Sep 10, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Heads on printer
go to the menu and select tools and settings. There should be an option to clean the heads.
If you mean clean the cartridge, take it out and using a sterile swab (not a q-tip), or a swab that doesn't release any fibers, dip it in rubbing alcohol and wipe the ink area with the swab. Keep doing this with a new swab each time until no ink is left, then print a alignment page.
Jun 18, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Nukote cartridge won't print
definitely call the company. the customer service line helped with some tips that got everything working.
May 27, 2008 | HP OfficeJet 4215 All-In-One InkJet...
4215xi printer
Please check :-
Protective tape on a new ink cartridge has been removed. Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
Then try and do a head clean and printer head alignment.
Dec 05, 2007 | HP Officejet 4215 All-in-One Color Photo...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
247 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
