My danze shower handle has a tub/shower diverter handle below the main handle. It used to divert water from tub to shower and back but now it does not. You can move it to either side but both tub and shower water comes out at the same time (one doesn't shut off). How to fix this?
SOURCE: Danze D500540BNT Brushed Nickel single handle leaks
only when its on? it can only be from 3 places the the plumbing up to shower head or the tub spout or crack in fixture make a hole in the wall behind fixture easier then replaceing tile if you can turn on and see where the water is coming from you need to open anyways thank you for useing fixya please rate me
SOURCE: Danze shower kit
SORRY, ITS SO.... BUT GOOD FOR YOU THIS ISN'T MY FIRST RODEO... TELL YOUR HUSBAND TO ADD THIS TO HIS NEVER ENDING TO-DO LIST: YOU CAN ADD A SHOWER HEAD VALVE WHICH DEPENDING ON YOUR FINISH ONLY COSTS ABOUT 15 DOLLARS AND TAKES 2 MINUTES TO INSTALL. I ACTUALLY HAVE ONE ON MY DANZE VENETIAN BRONZE TUB AND SHOWER FAUCET FOR THE EXACT SAME REASON. YOU SIMPLY REMOVE THE SHOWER HEAD, THEN ADD THE VALVE, THEN ATTACH THE SHOWER HEAD TO THE VALVE. ADJUST FOR THE DESIRED PRESSURE. SORRY HUBBIE
SOURCE: how do you tighten or remove handle on a danze
Not to familar with faucet itself, but on most shower faucet's, there is a screw that holds it on. Most of the time there is a plastic face plate on the front of the handles, you pop that off and the screw is beneath, as you loosen you have to hold the handle in place, otherwise as you loosen the screw it will turn the water on.
Other fauet handles will have a set screw , usually on the bottom side of the handle body,( the part of the handle closest to the shower wall, either a small flat head or allen wrech should be all you need. good luck.
SOURCE: need an instruction sheet for
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
SOURCE: dissassemble danze washerless shower valve
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
