Have opened back panel and the pulley and belt look good; I can turn the tub with the belt both clock and counter clockwise. the belt has good "riser" to fit in the motor shaft pulley. The belt does not appear to be stretched as had to "walk" it back on by rotating the large pulley
SOURCE: No movement in the wash tub - no spin - no agitator
The adjitator transmission is probably shot ;o(
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well and close the post.
Thank you – and enjoy your day ;o)
SOURCE: neptune MAH 4000AWW works good but some whater is left
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Hope your filter is clean. Don’t wait for the
machine to jam to
look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and
other such
things can be stuck around the inside tub of your washer. Try this
product, it
works great on all front loaders. Use very hot water with the Affresh
pellet
with no clothes and run the machine through a cycle. Also helps with any
stagnant water smells. Put the Affresh
pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the
free help,
can't you. Thanks.
SOURCE: I have an 11 year old Maytag Neptune Washer
hi that is a bad tub baring and seal which a costly fix at that age i don't think i would fix it
SOURCE: my maytag washer stopped working
If you turn the transmission pulley one way it will agitate the other it will get hard raise up to release the brake and then turn the transmission and the inner drum. If you cannot turn the drum then I would check to see if a nail has gone through one of the holes in the bottom of the drum or a piece of clothing has jammed between the top of the drum and the top cap of the outer tub.
