Question about Samsung Audio Players & Recorders
My mp3 player cannot play any thing it is of samsung ypu1 can you help me about it
Samsung mp3 player yp u 1
Posted by usaid_naeem on
Chris Hingee
  • Samsung Master
  • 32,281 Answers
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player using the USB cable.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Posted on May 02, 2012
5 Related Answers
kjanx
kj henriksen
  • 194 Answers
SOURCE: Samsung MP3 Player YP-Z5F
is there a reset button [pinhole] on the player??
should fix it
Posted on Feb 02, 2008
Anonymous
  • 6 Answers
SOURCE: Samsung YP-K3 MP3 Player
Available from Samsung suppoort site along with firmware upgrade tool
Posted on Jul 11, 2008
Anonymous
SOURCE: samsung mp3 yp-u3j no driver
download windows media player 11
once you install it follow these steps:
-right click my computer-click properties-click on hardware tab- then click on device manager
- plug in your yp-u3jqby mp3 player
-you should see your mp3 player pop up. double click it. then upgrade drivers.
after endless hours... i finally got it to work. i guess the trick is windows media player 11.
Posted on Sep 12, 2008
Anonymous
SOURCE: Samsung YP-K3 mp3 player requires driver but I have no cd!!
I've had this problem. Windows media player doesn't seem to find it, and I couldn't figure out which file I needed from the site. I have xp, but I'm assuming this might also work for vista. Go to Control Panel. Open System. Click the Hardware tab. Click the Device manager button. Find the yellow question mark labled Samsung YP-K3 and doubble click it. This should open a window that will let you (re)install the driver, which it will find for you after having you set up a few simple options. Hope this helps.
Posted on Aug 01, 2009
Anonymous
SOURCE: Samsung YP-U3 mp3 player display is DEAD..won't show menu
LCD broken,
Posted on Aug 20, 2009
Samsung YP-F1 stuck on 106.0 MHz - Radio Mode
open cover and use paper clip to reset it.
Feb 10, 2009 | Samsung Yepp YP-F1X MP3 Player
HELP ME PLEASE????
how do you text on mp822-4g touch screen mp3 player
Sep 04, 2008 | Samsung Yepp YP-T9 Digital Media Player
MP3 driving me mad
i cannot turn on my samsung 1G mp3 yp-1 after last recharge.
How can i turn it on or reset it?
Mar 15, 2008 | Samsung YP-Z5A MP3 Player
Samsung yp-k3 wont't accept mp4?
everything I google and read says mp3
http://www.samsung.com/uk/consumer/detail/spec.do?group=homeentertainment&type=mp3digitalaudio&subtype=yp_k3&model_cd=YP-K3JQB/XEU
Feb 23, 2008 | Samsung YP-K3 MP3 Player
YP-U2JXB & YP-U2JZW Won't sync...Help!
Error C00D1236 virtually always indicates one of two things:
1) The device is trying to sync hidden files--are there any?
2) There is licensed media that is being synced, and the license is either corrupt or has expired. If you have any licensed media, then try going back to where you purchased it (in an iTunes-like music management program? In WMP?) and refresh/renew the license.
The bad news is that until C00D1236 is resolved, you can't sync your device. frown.gif
You can bypass syncing, and directly transfer files, In my computer, the mp3 plaer will be shown as a drive.
Now if one of the two solutions above is not feasible for u, try this:
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
This error is common with Windows Media Player
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Nov 22, 2007 | Samsung YP-U2X Digital Media Player
YPU1 cannot read mp3 files
Format the mp3 player with FAT , not FAT 32,
and 16 bitar.
that will solve the problem of reading the files. It did for me :)
Aug 23, 2007 | Samsung YP-U1 MP3 Player
My Samsung YP-T9J MP3 will not play downloaded songs
if you have a error message license error, it means song is not properly authorized to be shared. is this "downloaded song", are they on mp3 format? if they are, try using windows media player, then synch it with the mp3 player. hope this helps!
Aug 17, 2007 | Samsung Yepp YP-T9 Digital Media Player
Mp3 problems
TRY THIS! Download the latest firmware and flash the MP3 player. Make sure you download the correct firmware for your MP3 player and follow the instruction carefully. Go here for the latest firmware: http://www.cczclan.com/yp-55download.asp Follow this link for older firmware and software from Samsung: http://www.cczclan.com/yp-55download.asp
Sep 05, 2006 | Samsung YP-MT6X MP3 Player
59 people viewed this question
Top Samsung Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
