My cable company disconnected my model av-36d502 tv and when they reconnected the cable box there was no color do I need the remote to remedy this problem because I don't have it
    Top Expert:
  • 14,553 Answers
If you are using a box unplug it and plug it back to let it boot up--if not have them back to verify the hookup etc is correct---they should without being asked also swap the box if used for another box.
Posted on May 02, 2012
6ya staff
SOURCE:
Anonymous
  • 12 Answers
SOURCE: tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Posted on Mar 29, 2009
Anonymous
  • 241 Answers
SOURCE: JVC Model AV-36D502 Blinking power light on start-up
you probably have some sort of overheating or short on the internal board - is it still on warranty? if so they will fix at no charge - if not, a local repair shop should be able to correct the problem but it may cost as much as $150
Posted on Jan 26, 2008
Anonymous
  • 57 Answers
SOURCE: RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Posted on Feb 28, 2009
Anonymous
  • 10 Answers
SOURCE: can't find code for JVC AV-27220 tv remote
Hi Please follow this link and u can get the full manual to fix the problem.
Please review and say if it helped thanx
<a href="http://www.nodevice.com/manual/newmans/AV-27220pdf/get16984.html">Download JVC AV-27220 Service Manual</a>
Posted on Apr 19, 2009
ikkenom
  • 10406 Answers
SOURCE: set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Posted on Apr 23, 2009
Want to connect my JVC AV-36D502 to my lap top computer
hi hmwpeg
• you may need a PC to TV Converter
like one of these:
http://sewelldirect.com/pc-to-tv.asp
instruction is on the web page.
• to enable on your laptop, set your JVC TV as secondary monitor.
• use the Catalyst control panel.
hope these helps
thanks for choosing Fixya for assistance
Sep 05, 2012 | JVC AV-36D502 36" TV
Jan 26, 2008 | JVC AV-36D502 36" TV
JVC AV-36D502 36
Check and replace the chroma IC.
Aug 13, 2012 | JVC AV-36D502 36" TV
I have a 27N-S100 TV. It was given to me with no remote. The Cable plug thing in the back is completely broken off, but I was told the TV could work perfectly by using the 3 colored cables (I believe they...
What you're trying to do shouldn't work unless the VCR has a digital tuner in it or your cable company still hasn't converted over to digital as of yet. You will need to get a digital cable box from your cable company.
Connect the av cables to either the front or back of the television. I believe the front is av/video 2 and the back is av/video 1. You have to choose either video 1 or video 2 from the television's menu in order to access these parts of your television.
Connect the cable box to the other end of the av cables and you should be all set. You would change channels with your cable remote and always leave the Sharp television on video or
What you're trying to do: Connect the cable to where it says in on the back of the vcr. and connect the av cables to the vcr where it says out. You will have to do a channel scan on the vcr.
Apr 26, 2011 | Sharp 27N-S100 27" TV
Toshiba 37WL66AS LCD TV troubleshooting color control Our Toshiba 37WL66AS LCD TV has an image color problem. Ever so often the screen goes reddish (especially skin tones). Turning the TV off for greater...
my toshiba tv.is around 6yrs. old...this morning when i tried to turn it on,..nothing...i have cable so i use a "box" & my cable company remote...i can turn on the box manually..the remote turns on my dvd player.{sony]...we had a blizzard start during the night..my cable company said they were having problems..i cannot turn on the tv manually..it does nothing at all...is there a safety feature that is causing the problem?..the model number is;27df46...serial number;BAB614020144A...PLEASE ADVISE...Fiona Duffy
Dec 05, 2009 | Toshiba Televison & Video
JVC AV-36D502: Input #3 doesn't work
Good day sir, its a different issue, about the capacitor, for as long as your replacement part is correct, it will work, now, there are several things you should check, the I/O device that controls the inputs of the TV, usually an IC, check your schematic diagram to trace the fault. check also the line from the input 3 to the controller IC on your diagram. Measure the voltage across the IC Vcc to ground if the IC is getting the right power, Low voltage can be cause by faulty capacitors, on the power supply line, or the IC itself is faulty, Circuit analysis and voltage measurements are needed to trace the faulty part. hope this helps thanks.
Oct 23, 2009 | JVC AV-36D502 36" TV
Thanks
Len
Feb 28, 2009 | JVC AV-32230 32" TV
Color not right
Sounds like you need to change your video cable. You can do this on your own by purchasing the cable that was damaged by the ladder from your local Best Buy, Cicuit City, Radio Shack, ect... and running it then reconnecting it in the areas that you disconnected it or you can call you local cable company to replace it for you (some companies charge a fee, mines do).
Dec 27, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Lost all sound
I had the same problem. Do you have a cable box for digital TV? do you have a remote from the cable company? that is programmed to control the TV? get the cable company to unlock the sound control from it (a 3 number code) put your sound up to maximum if you can if you hear faint sound repeat above you should be able to hear the tv then then go to the sound settings and adjust as needed get the cable company to check the box in cas it has been zapped by lighting good luck
Aug 26, 2007 | Protron PLTV-32 Television
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
