I need to know the power adapter polarity for a Blueparrott B250-XT Bluetooth Headset, either positive tip or negative tip polarity. Also, I need to know the correct Output voltage rating on the charger that comes with the headset.
SOURCE: I have the blueparrott b250-xt
If the green light comes on while you are charging the unit it means the battery is getting power. If the unit won't function or show any indicators while it is not on the charger there may be an issue with one of the control circuits. I recommend calling VXi, the makers of Blueparrott Headsets at 800-742-8588 for technical support. All VXi, Blueparrott Headsets have a one year warranty.
SOURCE: Hello my name is adei have blueparrott b250-xt so
You can get the manual on the link below.
http://www.blueparrott.com/pdfs/202711B_B250XTUserGuide.pdf
Good Luck and please rate 4 thumbs up for the free answer.
SOURCE: my dad has a blue
0000 thats zero's.. every device is always zero's unless you change the code.. it's universal
SOURCE: no audio blueparrott B250-XT
turn it off, plug headset (charging), unplug and let it pair with phone problem will be solved
SOURCE: my b250-xt headset battery goes
If the headset goes dead almost immediately after charging the issue is likely with one of the control circuits. In the unlikely event the battery is the issue is manufacturer replaceable only. I'd recommend calling VXi at 800-742-8588 for warranty repair option information.
