Epson Stylus NX400 InkJet Printer Logo
A
Anonymous Posted on May 01, 2012
Replace ink cartridge for epson stylus NX230 - Epson Stylus NX400 InkJet Printer
Sergio
Level 2:
Habit-Forming:
  • Expert 143 Answers
  • Posted on Aug 05, 2018
Sergio
Expert
Level 2:
Habit-Forming:
Answers
143
Questions
0
Helped
205385
Points
408
Here's a tutorial on how to do it:
Solved Epson printer doesnt recognize Ink Cartridge
4 Related Answers
Anonymous
  • Posted on Mar 18, 2010
SOURCE: Have an epson stylus nx110 printer and have to
Find the NX110 in the printers section of the control panel. Then right click your printer and choose "Printing Preferences" then the "Maintenance" tab. In there you will see a button for 'Replace ink cartrige'. Select that and it will take you through it step by step and even move the print heads to the correct position so you can change the ink.
Anonymous
  • 159 Answers
  • Posted on Feb 14, 2009
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Anonymous
  • 677 Answers
  • Posted on Mar 19, 2010
SOURCE: hi.igot an epson stylus sx125 i want to replace
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Anonymous
  • 428 Answers
  • Posted on Mar 24, 2010
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
1helpful
NX200. How can I change the ink cartridges?
Replace Ink Cartridges - Epson
files.support.epson.com > NX200UG.1.100.html
Replace Ink Cartridges. Your Epson Stylus NX200 Series and its software will let you know when an ink cartridge is low or expended. If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
Manual
Replacing Ink Cartridges - Epson STYLUS NX200 Series ...www.manualslib.com > ... > Quick manualEpson STYLUS NX200 Series Manual Online: Replacing Ink Cartridges. Make sure you have a new ink cartridge before you begin. You must install new ...Local results
Videos as well
https://www.google.com/search?q=epson+nx200+ink+cartridge+replacement
.. Anything else Denise, just click COMMENT under my post.
2helpful
No ink coming out of printer while printing
I use to have the same problem with my Lexmark printer. Maybe you should check to see if the ink became clogged. Just hold the ink cartridge over boiling water for about 4 minutes or so. Also are you sure the contacts and those things are not damaged?
Still having Problem Then follow Us For Epson Printer Support
Change ink cartridge epson NX230
Change Ink Cartridge in Epson Printer isn't a difficult. Just follow the simple steps to change ink cartridge in Epson Printer:
·Turn on Epson printer·Open its cover or scanner then left the unit of the scanner and wait for it.
·Ensure that the print head is at replacement position. If not the press "Maintenance" button.
Follow the more steps to change ink cartridge in Epson Printer.
2answers
Dose the printer epson stylus NX125\127 comes with a USB wire?
Yes
http://www.epson.com.au/products/multifunctional/stylusnx125_specs.asp
but you can buy one yourself for less than $5.
1helpful
Epson Stylus TX400. Refuses to accept either compatable or refilled cartridges?
Epson TX400 is so sensitive in terms of ink cartridges, you can only replace a refilled ink cartridge in this type of printer if the cartridge has an automatic ink reseter chip. When you replace a cartridge in your printer, it will automatically register the ink level in the chip. So you need an ink reseter chip to replace a new refilled cartridge.
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
2answers
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Warning:
Note:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
1helpful
How do I replace ink cartridge?
you can use the maintenance utility on your driver to perform ink cartridge replacement. or you can perform this method should you be using it stand alone:
Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
1. Turn on the Epson Stylus NX400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus NX400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement.
If you’re replacing a cartridge before you see a message on the Epson Stylus NX400 Series
LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK.
follow on through each one of the inks and it should be good there on
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
